查看: 13965|回复: 15
[经验分享] 有用MikroTik路由器的吗?开启device_tracker出错【用SNMP搞定】
发表于 2019-1-15 20:51:15 | 显示全部楼层 |阅读模式
听大神意见,用SNMP搞定了,哈哈:
device_tracker:
  - platform: snmp
    host: 192.168.1.1
    community: public
    baseoid: 1.3.6.1.2.1.4.22.1.2
旧问题:
开启device_tracker后,
device_tracker:
  - platform: mikrotik
    host: 192.168.1.1
    username: admin
    password: xxxxxxx
日志显示:
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 176, in async_setup_platform
    platform.get_scanner, hass, {DOMAIN: p_config})
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/mikrotik.py", line 38, in get_scanner
    scanner = MikrotikScanner(config[DOMAIN])
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/mikrotik.py", line 70, in __init__
    self._update_info()
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/mikrotik.py", line 184, in _update_info
    cmd='/caps-man/registration-table/getall')
  File "/config/deps/lib/python3.6/site-packages/librouteros/api.py", line 80, in __call__
    return self._readResponse()
  File "/config/deps/lib/python3.6/site-packages/librouteros/api.py", line 103, in _readResponse
    reply_word, words = self._readSentence()
  File "/config/deps/lib/python3.6/site-packages/librouteros/api.py", line 88, in _readSentence
    reply_word, words = self.protocol.readSentence()
  File "/config/deps/lib/python3.6/site-packages/librouteros/connections.py", line 147, in readSentence
    sentence = tuple(word for word in iter(self.readWord, b'\x00'))
  File "/config/deps/lib/python3.6/site-packages/librouteros/connections.py", line 164, in readWord
    return self.transport.read(length).decode(encoding=self.encoding, errors='strict')
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xb0 in position 11: invalid start byte
请问大神,问题出在哪里了?
发表于 2019-1-15 22:43:54 | 显示全部楼层
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xb0 in position 11: invalid start byte  尝试将路由器语言设置为英语试试  我也不懂 瞎猜的
发表于 2019-1-15 22:44:56 | 显示全部楼层
或者设备名有中文
 楼主| 发表于 2019-1-15 23:37:33 | 显示全部楼层
余歌唱晚 发表于 2019-1-15 22:43
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xb0 in position 11: invalid start byte  尝试将 ...
路由器本来没有中文,系统也是英文的设置
发表于 2019-1-16 09:48:01 | 显示全部楼层
我的ros一直使用的snmp,device_tracker用的非常完美。
 楼主| 发表于 2019-1-16 23:36:21 | 显示全部楼层
用SNMP搞定了,换个思路海阔天空啊,哈哈
发表于 2019-6-12 00:42:38 | 显示全部楼层
請問下~ baseoid: 1.3.6.1.2.1.4.22.1.2 這串數字哪來的????能解惑嗎? 感激不進~~己解決~謝謝~~~
发表于 2020-1-10 14:06:30 | 显示全部楼层
请问这两个个参数怎么找?
community: public
发表于 2020-1-10 15:50:11 | 显示全部楼层
看了下普通家用路由器很少支持SNMP协议的
发表于 2020-1-10 23:34:15 | 显示全部楼层
mikrotik:
  - host: 192.168.1.253
    username: !secret mikrotik_user
    password: !secret mikrotik_password
    login_method: token
    ssl: false
    method: dhcp
    track_devices: true
ros版本在6.43之前的login_method要用token,之后的用plain
GMT+8, 2026-1-19 21:10 , Processed in 0.341832 second(s), 12 queries , MemCached On.
