查看: 7491|回复: 5
[求助] aqara空调伴侣接入出错
发表于 2019-1-15 01:30:33 | 显示全部楼层 |阅读模式
以前是两个网关,接入正常,后来一个网关电量统计有问题退货了。现在单个网关接入报错。求助
Error during setup of component xiaomi_aqara
  File "/usr/src/app/homeassistant/setup.py", line 148, in _async_setup_component
    component.setup, hass, processed_config)  # type: ignore
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/src/app/homeassistant/components/xiaomi_aqara.py", line 129, in setup
    xiaomi.discover_gateways()
  File "/usr/local/lib/python3.6/site-packages/xiaomi_gateway/__init__.py", line 107, in discover_gateways
    resp["proto_version"] if "proto_version" in resp else None)
  File "/usr/local/lib/python3.6/site-packages/xiaomi_gateway/__init__.py", line 209, in __init__
    if self._discover_devices():
  File "/usr/local/lib/python3.6/site-packages/xiaomi_gateway/__init__.py", line 216, in _discover_devices
    else self._send_cmd(cmd, "discovery_rsp")
  File "/usr/local/lib/python3.6/site-packages/xiaomi_gateway/__init__.py", line 309, in _send_cmd
    resp = json.loads(data.decode())
  File "/usr/local/lib/python3.6/json/__init__.py", line 354, in loads
    return _default_decoder.decode(s)
  File "/usr/local/lib/python3.6/json/decoder.py", line 339, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/local/lib/python3.6/json/decoder.py", line 355, in raw_decode
    obj, end = self.scan_once(s, idx)
json.decoder.JSONDecodeError: Unterminated string starting at: line 1 column 1022 (char 1021)
 楼主| 发表于 2019-1-15 10:06:20 来自手机 | 显示全部楼层
难道是因为我的mac地址写了冒号?
 楼主| 发表于 2019-1-17 18:17:54 | 显示全部楼层
有人帮我看看吗?还没解决
 楼主| 发表于 2019-1-19 18:57:38 | 显示全部楼层
实在是搞不清楚为什么会这样了。
 楼主| 发表于 2019-1-22 09:40:57 来自手机 | 显示全部楼层
已解决,疑似添加设备过多导致。
发表于 2020-2-29 19:16:57 | 显示全部楼层
谢谢,出现一样的问题。花不少时间重新安装,解不了。直到看到这文,才解。
GMT+8, 2025-12-23 12:13 , Processed in 0.297632 second(s), 15 queries , MemCached On.
