查看: 14396|回复: 14
[技术探讨] 配置好hassio后,总是出现xiaomi-aqara配置错误,如何解决
发表于 2019-1-10 18:18:53 | 显示全部楼层 |阅读模式
各位大佬,N1装的docker后装hassio成功,已经和M1通信成功,但是总是出现这个问题:
The following components and platforms could not be set up:
Please check your config.
实际还有个
  • [color=var(--primary-color)]sun 的错误,后来在配置文件里面把sun屏蔽了!
  • 实际配置文件configuration.yaml里面并没有设置
  • [color=var(--primary-color)]xiaomi-aqara的选项!
  • 具体是什么问题?
此外,无论配置yr天气还是其他天气插件均无法工作,请问是什么问题?
先谢谢各位
configuration.rar
1.03 KB, 下载次数: 38
发表于 2019-1-10 21:56:10 | 显示全部楼层
消灭0回复,看下日志吧
发表于 2019-1-11 15:52:01 | 显示全部楼层
我的也经常这个样子的哈,进入之后随便修改些东西,再保存吧。
发表于 2019-1-20 20:27:34 | 显示全部楼层
我跟你一样的报错,但是我在文件配置了xiaomi_aqara。不知道为什么,还有其他报错,在信息那个地方
Error during setup of component xiaomi_aqara
  File "/usr/src/app/homeassistant/setup.py", line 148, in _async_setup_component
    component.setup, hass, processed_config)  # type: ignore
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/src/app/homeassistant/components/xiaomi_aqara.py", line 129, in setup
    xiaomi.discover_gateways()
  File "/usr/local/lib/python3.6/site-packages/xiaomi_gateway/__init__.py", line 107, in discover_gateways
    resp["proto_version"] if "proto_version" in resp else None)
  File "/usr/local/lib/python3.6/site-packages/xiaomi_gateway/__init__.py", line 209, in __init__
    if self._discover_devices():
  File "/usr/local/lib/python3.6/site-packages/xiaomi_gateway/__init__.py", line 216, in _discover_devices
    else self._send_cmd(cmd, "discovery_rsp")
  File "/usr/local/lib/python3.6/site-packages/xiaomi_gateway/__init__.py", line 309, in _send_cmd
    resp = json.loads(data.decode())
  File "/usr/local/lib/python3.6/json/__init__.py", line 354, in loads
    return _default_decoder.decode(s)
  File "/usr/local/lib/python3.6/json/decoder.py", line 339, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/local/lib/python3.6/json/decoder.py", line 355, in raw_decode
    obj, end = self.scan_once(s, idx)
json.decoder.JSONDecodeError: Unterminated string starting at: line 1 column 1022 (char 1021)
发表于 2019-1-21 22:34:06 | 显示全部楼层
我也出现过,不知道原理,但是解决了。我是一个刷了op的机器,下层有一个poe路由器,接lan当交换机的,ap挂在poe路由器上。之前ss不是很稳,重启op,然后就出现网关找不到的情况,重启poe路由器就好了。推测还是网络环境的问题。
发表于 2019-8-3 21:02:15 | 显示全部楼层
我也出现这个问题,路由器重启过了,配置文件也修改了,还是这样,怎么办???
系统重装后还是没有解决问题。
xiaomi_aqara:
  interface: '192.168.28.29'
  gateways:
    - mac: 7811dcb7b141
      key: fgau3y2ipe5mzovb
2019-08-03 23:19:21 ERROR (MainThread) [homeassistant.setup] Error during setup of component xiaomi_aqara
  File "/usr/src/homeassistant/homeassistant/setup.py", line 156, in _async_setup_component
  File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run
  File "/usr/src/homeassistant/homeassistant/components/xiaomi_aqara/__init__.py", line 132, in setup
  File "/usr/local/lib/python3.7/site-packages/xiaomi_gateway/__init__.py", line 47, in discover_gateways
    _socket.bind((self._interface, 0))
OSError: [Errno 99] Address not available
发表于 2019-10-12 16:53:55 来自手机 | 显示全部楼层
我也是这个问题  你最后有解决吗?
发表于 2020-4-11 01:39:11 | 显示全部楼层
系统重装后还是没有解决问 ...
你出现OSError: [Errno 99] Address not available的事情,HA能正常启动,我现在也是这情况,HA完全不能启动了,准备重刷
发表于 2020-6-19 04:31:49 | 显示全部楼层
楼上几位大哥是不是都用的N1装docker来部署homeassistant的?我也一样有这样的问题,网关添加不了。
发表于 2020-6-19 20:34:20 | 显示全部楼层
问题已经解决了。在官方文档里面有提到
If you are using Home Assistant in Docker, make sure to use --net=host,无法加载的原因是在DOCKER里面没设置使用宿主网络的话,镜像的网络和宿主的是不一致的,不在同一个网络自然就无法配置设备。
GMT+8, 2025-12-29 22:20 , Processed in 0.256058 second(s), 14 queries , MemCached On.
