查看: 5040|回复: 9
[技术探讨] 树莓派3B+虚拟环境安装,无法安装百度tts组件
发表于 2019-1-9 14:15:56 | 显示全部楼层 |阅读模式
恢复之前的HA0.84.3镜像备份好用,因为已经装过百度tts了
新装的话0.84.3和0.84.6都不好用,升级python到3.6.8也不行。
是因为网络 问题吗?还是现在的版本问题?
2019-01-09 14:09:20 INFO (SyncWorker_12) [homeassistant.util.package] Attempting install of baidu-aip==1.6.6
2019-01-09 14:09:21 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 2.1 seconds.
2019-01-09 14:11:49 ERROR (SyncWorker_12) [homeassistant.util.package] Unable to install package baidu-aip==1.6.6: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))': /simple/pillow/
  Failed building wheel for Pillow
Command "/srv/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-hq2nrek_/Pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-gwo2j7sk/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.6/Pillow" failed with error code 1 in /tmp/pip-install-hq2nrek_/Pillow/
2019-01-09 14:11:49 ERROR (MainThread) [homeassistant.requirements] Not initializing tts.baidu because could not install requirement baidu-aip==1.6.6
2019-01-09 14:11:49 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform tts.baidu: Could not install all requirements.
 楼主| 发表于 2019-1-9 14:31:25 | 显示全部楼层
L大的帖子,自定义组件可以使用
https://bbs.hassbian.com/thread-1152-1-1.html
发表于 2019-1-10 10:50:17 | 显示全部楼层
5、homeassistant 安装 百度TTS
sudo apt-get install libtiff5-dev libtiff5 libjbig-dev
进入虚拟
sudo su -s /bin/bash homeassistant
cd /srv/homeassistant
source bin/activate
pip3 install baidu-aip==1.6.6
试试
 楼主| 发表于 2019-1-11 13:39:05 | 显示全部楼层
进入虚拟
依然不行:
(homeassistant) homeassistant@raspberrypi:/srv/homeassistant $ pip3 install baidu-aip==1.6.6
Looking in indexes: [url]https://pypi.org/simple[/url], [url]https://www.piwheels.org/simple[/url]
Collecting baidu-aip==1.6.6
  Using cached [url]https://www.piwheels.org/simple/baidu-aip/baidu_aip-1.6.6.0-py3-none-any.whl[/url]
Collecting Pillow (from baidu-aip==1.6.6)
  Using cached [url]https://files.pythonhosted.org/packages/3c/7e/443be24431324bd34d22dd9d11cc845d995bcd3b500676bcf23142756975/Pillow-5.4.1.tar.gz[/url]
Requirement already satisfied: requests in ./lib/python3.6/site-packages (from baidu-aip==1.6.6) (2.20.1)
Requirement already satisfied: urllib3<1.25,>=1.21.1 in ./lib/python3.6/site-packages (from requests->baidu-aip==1.6.6) (1.24.1)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in ./lib/python3.6/site-packages (from requests->baidu-aip==1.6.6) (3.0.4)
Requirement already satisfied: idna<2.8,>=2.5 in ./lib/python3.6/site-packages (from requests->baidu-aip==1.6.6) (2.7)
Requirement already satisfied: certifi>=2017.4.17 in ./lib/python3.6/site-packages (from requests->baidu-aip==1.6.6) (2018.11.29)
Building wheels for collected packages: Pillow
  Running setup.py bdist_wheel for Pillow ... error
  Complete output from command /srv/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-mbizym8p/Pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-vs0naqan --python-tag cp36:
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-armv7l-3.6
  creating build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/OleFileIO.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageQt.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/GifImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/PalmImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/PcdImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/MicImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/XpmImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/SgiImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/TiffTags.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ContainerIO.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/GbrImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/GimpPaletteFile.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/PpmImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageDraw2.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/PSDraw.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageFile.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/TiffImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/DdsImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/PngImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/Jpeg2KImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/EpsImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/FitsStubImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImagePath.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageEnhance.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/Image.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/TarIO.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/McIdasImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/Hdf5StubImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/PaletteFile.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/MspImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/__init__.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/FtexImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/_util.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/BufrStubImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/GdImageFile.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageTransform.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/PdfImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/PixarImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageShow.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageWin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/DcxImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/FpxImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/WmfImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageMorph.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/PcxImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageStat.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/WalImageFile.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/GribStubImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/XbmImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageTk.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/JpegPresets.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/WebPImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/IptcImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/_binary.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/features.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageChops.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/BdfFontFile.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageCms.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageColor.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageFont.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/FliImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageGrab.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/PyAccess.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/FontFile.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageDraw.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/_version.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/IcoImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageMath.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/SunImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/SpiderImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageMode.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageOps.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImagePalette.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/CurImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/MpoImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/IcnsImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/PcfFontFile.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/TgaImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageFilter.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImtImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/PdfParser.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/XVThumbImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/BlpImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/JpegImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/PsdImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ImageSequence.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/MpegImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/GimpGradientFile.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/ExifTags.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/BmpImagePlugin.py -> build/lib.linux-armv7l-3.6/PIL
  copying src/PIL/_tkinter_finder.py -> build/lib.linux-armv7l-3.6/PIL
  running egg_info
  writing src/Pillow.egg-info/PKG-INFO
  writing dependency_links to src/Pillow.egg-info/dependency_links.txt
  writing top-level names to src/Pillow.egg-info/top_level.txt
  reading manifest file 'src/Pillow.egg-info/SOURCES.txt'
  reading manifest template 'MANIFEST.in'
  warning: no files found matching '*.c'
  warning: no files found matching '*.h'
  warning: no files found matching '*.sh'
  no previously-included directories found matching 'docs/_static'
  warning: no previously-included files found matching '.appveyor.yml'
  warning: no previously-included files found matching '.coveragerc'
  warning: no previously-included files found matching '.codecov.yml'
  warning: no previously-included files found matching '.editorconfig'
  warning: no previously-included files found matching '.landscape.yaml'
  warning: no previously-included files found matching '.readthedocs.yml'
  warning: no previously-included files found matching '.travis'
  warning: no previously-included files found matching '.travis/*'
  warning: no previously-included files found matching 'tox.ini'
  warning: no previously-included files matching '.git*' found anywhere in distribution
  warning: no previously-included files matching '*.pyc' found anywhere in distribution
  warning: no previously-included files matching '*.so' found anywhere in distribution
  writing manifest file 'src/Pillow.egg-info/SOURCES.txt'
  running build_ext
  The headers or library files could not be found for jpeg,
  a required dependency when compiling Pillow from source.
  Please see the install instructions at:
     [url]https://pillow.readthedocs.io/en/latest/installation.html[/url]
    File "/tmp/pip-install-mbizym8p/Pillow/setup.py", line 800, in <module>
      zip_safe=not (debug_build() or PLATFORM_MINGW), )
    File "/srv/homeassistant/lib/python3.6/site-packages/setuptools/__init__.py", line 143, in setup
      return distutils.core.setup(**attrs)
    File "/usr/local/lib/python3.6/distutils/core.py", line 148, in setup
      dist.run_commands()
    File "/usr/local/lib/python3.6/distutils/dist.py", line 955, in run_commands
      self.run_command(cmd)
    File "/usr/local/lib/python3.6/distutils/dist.py", line 974, in run_command
      cmd_obj.run()
    File "/srv/homeassistant/lib/python3.6/site-packages/wheel/bdist_wheel.py", line 188, in run
      self.run_command('build')
    File "/usr/local/lib/python3.6/distutils/cmd.py", line 313, in run_command
      self.distribution.run_command(command)
      cmd_obj.run()
    File "/usr/local/lib/python3.6/distutils/command/build.py", line 135, in run
      self.run_command(cmd_name)
      cmd_obj.run()
    File "/usr/local/lib/python3.6/distutils/command/build_ext.py", line 339, in run
      self.build_extensions()
    File "/tmp/pip-install-mbizym8p/Pillow/setup.py", line 612, in build_extensions
      raise RequiredDependencyException(f)
  __main__.RequiredDependencyException: jpeg
    File "<string>", line 1, in <module>
    File "/tmp/pip-install-mbizym8p/Pillow/setup.py", line 812, in <module>
      raise RequiredDependencyException(msg)
  Running setup.py clean for Pillow
Failed to build Pillow
Installing collected packages: Pillow, baidu-aip
  Running setup.py install for Pillow ... error
    Complete output from command /srv/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-mbizym8p/Pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-exa487j4/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.6/Pillow:
    running install
    running build
    running build_py
    creating build
    running egg_info
    running build_ext
 楼主| 发表于 2019-1-11 13:45:09 | 显示全部楼层
另外之前我还尝试发现:
  Downloading [url]https://www.piwheels.org/simple/baidu-aip/baidu_aip-2.2.11.0-py3-none-any.whl[/url]
Requirement already satisfied: requests in ./lib/python3.6/site-packages (from baidu-aip) (2.20.1)
Requirement already satisfied: idna<2.8,>=2.5 in ./lib/python3.6/site-packages (from requests->baidu-aip) (2.7)
Requirement already satisfied: certifi>=2017.4.17 in ./lib/python3.6/site-packages (from requests->baidu-aip) (2018.11.29)
Requirement already satisfied: urllib3<1.25,>=1.21.1 in ./lib/python3.6/site-packages (from requests->baidu-aip) (1.24.1)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in ./lib/python3.6/site-packages (from requests->baidu-aip) (3.0.4)
Installing collected packages: baidu-aip
Successfully installed baidu-aip-2.2.11.0
发表于 2019-2-7 22:47:31 来自手机 | 显示全部楼层
我也出现了这个情况
发表于 2019-3-18 15:51:20 | 显示全部楼层
baidu-aip-1.6.6目前不可用了,我也在求解决办法。。
发表于 2019-3-19 18:13:42 | 显示全部楼层
sudo apt install libjpeg-dev zlib1g-dev
sudo -u homeassistant -H -s
cd /srv/homeassistant/
python3 -m venv .
source bin/activate
exit
sudo reboot
参与人数 1金钱 +2 收起 理由
arrive + 2 感谢楼主分享!
发表于 2019-5-9 15:53:52 | 显示全部楼层
牛叉
发表于 2019-5-9 16:10:44 | 显示全部楼层
正解@turtlepeak
GMT+8, 2025-12-16 15:51 , Processed in 1.273115 second(s), 15 queries , MemCached On.
