查看: 7506|回复: 3
[技术探讨] 有人碰到过小米网关每天早上定时关闭导致HA关闭吗?
发表于 2019-1-6 12:44:40 | 显示全部楼层 |阅读模式
已经连续三天早上 6 点 25 之后 Home Assistant 就没有反应了,请教一下可能是什么原因导致的,谢谢!以下是最后的一段日志。
2019-01-06 06:25:00 INFO (MainThread) [homeassistant.components.device_tracker.asuswrt] Checking Devices
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25556] Requesting new SSH session
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25556]   Command: PATH=$PATH:/bin:/usr/sbin:/sbin && for dev in `nvram get wl1_vifs && nvram get wl0_vifs && nvram get wl_ifnames`; do if type wlanconfig > /dev/null; then wlanconfig $dev list | awk 'FNR > 1 {print substr($1, 0, 18)}'; else wl -i $dev assoclist; fi; done
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25556] Received exit status 0
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25556] Received channel close
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25556] Channel closed
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25557] Requesting new SSH session
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25557]   Command: PATH=$PATH:/bin:/usr/sbin:/sbin && arp -n
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25557] Received exit status 0
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25557] Received channel close
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25557] Channel closed
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25558] Requesting new SSH session
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25558]   Command: PATH=$PATH:/bin:/usr/sbin:/sbin && ip neigh
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25558] Received exit status 0
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25558] Received channel close
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25558] Channel closed
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25559] Requesting new SSH session
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25559]   Command: PATH=$PATH:/bin:/usr/sbin:/sbin && cat /var/lib/misc/dnsmasq.leases
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25559] Received exit status 0
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25559] Received channel close
2019-01-06 06:25:00 INFO (MainThread) [asyncssh] [conn=0, chan=25559] Channel closed
2019-01-06 06:25:06 INFO (Thread-4) [homeassistant.components.xiaomi_aqara] Shutting down Xiaomi Hub
2019-01-06 06:25:06 INFO (Thread-4) [xiaomi_gateway] Closing multisocket
2019-01-06 06:25:06 INFO (Thread-33) [pyhap.accessory_driver] Stopping accessory Home Assistant Bridge on address 192.168.2.177, port 51827.
流水无味
灌水之王
发表于 2019-1-6 18:29:33 | 显示全部楼层
小米网关问题多着呢,没事别去动他别去升级他
我至今有个别传感器反应迟钝
 楼主| 发表于 2019-1-6 22:44:23 | 显示全部楼层
我至今有个别传感器反应迟钝 ...
嗯,也不知道是 HA 平台的问题还是小米网关的问题。暂时只能每天定时重启树莓派了。
 楼主| 发表于 2019-1-17 23:41:24 | 显示全部楼层
经过几天的琢磨,终于搞明白原因了。
原因是,设置的自动启动方式是 init.d 方式,配置 /etc/logrotate.d/homeassistant 的时候,logrotate 每天早晨 6:25 的时候会截断处理日志,导致 hass 进程被重启。但是重启的动作只完成了停止,启动的动作没有运行(不知道为啥)。
换了另外一种自动启动方式 systemd,明早再看看会不会发生类似情况。
不好意思让小米网关背锅了~~
GMT+8, 2026-1-2 06:36 , Processed in 1.350499 second(s), 13 queries , MemCached On.
