查看: 9001|回复: 4
[已解决] HomeAssistant可以显示配件,家庭app无法搜索匹配到配件
发表于 2017-7-19 16:45:03 | 显示全部楼层 |阅读模式
按照论坛教程在群辉916+ docker 上安装配置好了hb 和 ha,都能正常启动家庭APP里怎么都搜索不到设备,求助~
config.json
    "bridge": {
        "name": "KniFe's Homebridge",
        "username": "00:11:32:6D:F2:4F",
        "port": 51691,
        "pin": "023-66-919"
    "platforms": [
            "platform": "AqaraPlatform",
            "sid": [
                "34CE0088E592"
            "password": [
                "9C07183BE1424EB2"
                        "platform": "HomeAssistant",
                        "name": "HomeAssistant",
                        "host": "http://127.0.0.1:8123",
                        "password": "123456a",
                        "supported_types": ["binary_sensor", "cover", "fan", "input_boolean", "light", "lock", "media_player", "scene", "sensor", "switch"],
                        "logging": true
    "accessories": [
            "accessory": "Synology",
            "name": "K_DS",
            "ip": "192.168.1.8",
            "mac": "00:11:32:6D:F2:4F",
            "port": "5000",
            "secure": false,
            "account": "miniknife",
            "version": 6
重启路由器以后问题解决,希望有同样问题的同学试试
发表于 2017-7-19 18:48:45 | 显示全部楼层
我之前碰到搜不到一般是Homebridge出问题~
sudo systemctl status homebridge
看看有没有报错~
HA网页打不开用
sudo su -s /bin/bash homeassistant
source /srv/homeassistant/bin/activate
hass --script check_config
希望能帮到你
发表于 2017-7-19 19:17:39 | 显示全部楼层
启动HA时查看HA容器的日志和终端机的提示看有没有错误。如没有错误,再启动homebridge ,同样查看homebridge 容器的日志和终端机的提示看有没有错误提示,根据错误提示解决问题。你的homebridge 容器的日志和终端机的提示是下面的图示一样了,才可以到你的APP连接看有没有你的设备
 楼主| 发表于 2017-7-19 19:24:41 | 显示全部楼层
感谢楼上两位回复
查看日志,报了一个错误
 楼主| 发表于 2017-7-21 15:38:01 | 显示全部楼层
感谢楼上两位,重启路由器以后问题解决
GMT+8, 2025-12-25 15:52 , Processed in 0.404109 second(s), 9 queries , MemCached On.
