查看: 7304|回复: 3
[技术探讨] 我的几个新版的sonoff反馈的状态怎么老是出错
发表于 2018-12-26 17:17:16 | 显示全部楼层 |阅读模式
比如sonoff1明明打开着,ha、hb里显示又是关闭状态。不知道问题出在哪?
sonoff控制台执行了
PowerOnState 1
powerretain 1
switchretain 1
10:27:04 MQT: 已连接
10:27:04 MQT: tele/S8/LWT = 在线 (已保留)
10:27:04 MQT: cmnd/S8/POWER =
10:27:04 MQT: tele/S8/INFO1 = {"Module":"Sonoff Basic","Version":"6.4.0(sonoff)","FallbackTopic":"DVES_86B506","GroupTopic":"sonoffs"}
10:27:04 MQT: tele/S8/INFO2 = {"WebServerMode":"Admin","Hostname":"SONOFF_8","IPAddress":"192.168.1.163"}
10:27:04 MQT: tele/S8/INFO3 = {"RestartReason":"ower on"}
10:27:04 MQT: stat/S8/RESULT = {"OWER":"ON"}
10:27:04 MQT: stat/S8/POWER = ON (已保留)
10:27:04 MQT: stat/S8/RESULT = {"OWER":"OFF"}
10:27:04 MQT: stat/S8/POWER = OFF (已保留)
10:27:12 MQT: tele/S8/STATE = {"Time":"2018-12-26T10:27:12","Uptime":"0T00:00:14","Vcc":3.478,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"OWER":"OFF","Wifi":{"AP":1,"SSId":"MyHome_2.4GHz","BSSId":"60:38:E0:8C:15A","Channel":13,"RSSI":60}}
10:27:13 MQT: stat/S8/RESULT = {"OWER":"ON"}
10:27:13 MQT: stat/S8/POWER = ON (已保留)
10:27:27 MQT: stat/S8/RESULT = {"OWER":"OFF"}
10:27:27 MQT: stat/S8/POWER = OFF (已保留)
发表于 2018-12-26 17:23:59 | 显示全部楼层
mqtt没同步吧?反复点击一下replay看状态是不是正常了
mitu 手机认证
发表于 2018-12-26 20:13:20 | 显示全部楼层
应该是HA中MQTT开关配置有问题。
我是这样配置的,没有任何问题。。
switch:
  - platform: mqtt
    state_topic: "tele/sonoff/STATE"
    value_template: "{{ value_json.POWER }}"
    command_topic: "cmnd/sonoff/POWER"
    availability_topic: "tele/sonoff/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    payload_available: "在线"
    payload_not_available: "不在线"
    retain: false
 楼主| 发表于 2018-12-27 13:16:34 | 显示全部楼层
mitu 发表于 2018-12-26 20:13
应该是HA中MQTT开关配置有问题。
我是这样配置的,没有任何问题。。
谢谢,回头试试
GMT+8, 2026-1-2 08:45 , Processed in 0.298474 second(s), 6 queries , MemCached On.
