查看: 36995|回复: 22
[基础教程] 空调伴侣升级版lumi.acpartner.v3米家无线开关WXKG01LM自动化使用
发表于 2018-12-26 12:47:59 | 显示全部楼层 |阅读模式
使用官方自带组件configuration.yaml配置如下:
#### [url=https://www.home-assistant.io/components/xiaomi_aqara/]https://www.home-assistant.io/components/xiaomi_aqara/[/url]
#### [url=https://www.home-assistant.io/components/binary_sensor.xiaomi_aqara/]https://www.home-assistant.io/co ... ensor.xiaomi_aqara/[/url]
xiaomi_aqara:
  discovery_retry: 10
  gateways:
    ##Aqara空调伴侣(升级版)Aqara Air Conditioning Companion (lumi.acpartner.v3)
    ##也可以从Aqara的APP打开局域网通讯协议,
    ##米家APP右上角 功能设置——”插件版本" 多次点击
    - mac: 7C49FC1E0524
      key: avcd01adrfed9856
使用最新的自定义组件configuration.yaml配置如下:组件下载:https://github.com/syssi/xiaomi_airconditioningcompanion
### 小米空调伴侣自定义组件 2018-12-26本地文件更新
### [url=https://github.com/syssi/xiaomi_airconditioningcompanion]https://github.com/syssi/xiaomi_airconditioningcompanion[/url]
### 安装位置 custom_components\climate\xiaomi_miio.py
climate:
  - platform: xiaomi_miio
    name: 空调伴侣升级版Aqara V3 KTBL11LM
    host: 192.168.100.200
    token: c36074b8e0a93093f7af5dde4a4ac1ac
    target_sensor: sensor.temperature_158d0526401ed8
    scan_interval: 60
通过点击无线开关,tts语音播报天气情况
#### 脑洞大开系列【自动化】教程 之 一键播报彩云即时天气
#### [url=https://bbs.hassbian.com/thread-899-1-1.html]https://bbs.hassbian.com/thread-899-1-1.html[/url]
#### 小米无线开关 binary_sensor.switch_158d00028a6866
#### 依赖:彩云天气S、小米无线开关
#### 相关帖子 [url=https://bbs.hassbian.com/thread-1014-1-1.html]https://bbs.hassbian.com/thread-1014-1-1.html[/url]
- alias: Manual_say_weather
  condition:
    condition: time
    after: '06:00:00'
    before: '22:00:00'
  trigger:
    - platform: event
      #### 事件类型为xiaomi_aqara.click
      event_type: xiaomi_aqara.click
      event_data:
        entity_id: binary_sensor.switch_158d00028a6866
        click_type: single
  action:
    - service: tts.baidu_say
      data_template:
        entity_id: media_player.pc__windows_media_player
        message:  >
          "手动播报天气{{states('sensor.caiyun_realtime_skycon')}}, 空气质量指数为{{states('sensor.caiyun_realtime_aqi')}},湿度为{{states('sensor.caiyun_realtime_humidity')}}
          温度是{{states('sensor.caiyun_realtime_temperature')}}℃,
          {{states('sensor.caiyun_minutely_description')}},降雨量是
          {{states('sensor.caiyun_precipitation_nearest_precipitation_intensity')}}毫米,
          所在地区的降雨量为{{states('sensor.caiyun_precipitation_local_precipitation_intensity')}}毫米"
        cache: false
认真的看了官方的组件文档终于弄好了这个点击开关播报天气的操作
调试过程中无线开关连接在空调伴侣升级版上,点击、双击时,Home Assistant反馈的开关动作全部正确,手动触发自动化,也正确播报。最后发现这个event_type: xiaomi_aqara.click,不是event_type: click,所以开关点击没有触发自动化。
文章都是有时效性的,所以大家爬论坛的时候还是要自己认真看一下,别拿来主义。
因为使用lua格式的代码引用,####后面的url地址转义后好长好长。
参与人数 2金钱 +26 收起 理由
jyz_0501 + 6 写的配置很清晰 连引用的原帖地址都放出来.
neroxps + 20 认真看完文档,加分
发表于 2018-12-26 13:10:48 | 显示全部楼层
不支持长按 跟摇一摇  很蛋疼
发表于 2018-12-26 13:44:26 | 显示全部楼层
就冲着认真看文档搞定这句 加分~!
其实事件不是教程错误,是ha新版改版后事件名字变了~所以看文档很重要
发表于 2018-12-26 14:22:28 | 显示全部楼层
这一看,貌似插件又更新了啊
发表于 2018-12-26 14:28:56 | 显示全部楼层
教程有什么错 当时源码就这么写的
现在更新了,教程没改而已
 楼主| 发表于 2018-12-26 15:17:22 | 显示全部楼层
Mozziz 发表于 2018-12-26 13:10
不支持长按 跟摇一摇  很蛋疼
嗯,官方说支持一代的长按,测试其实是不好用的。
 楼主| 发表于 2018-12-26 15:20:18 | 显示全部楼层
改一下措辞,省的叽歪
流水无味
灌水之王
发表于 2018-12-26 16:24:14 | 显示全部楼层
教程在HA更新前 没毛病
论坛好多教程特别是17年的就当参考
活跃会员教程狂人
发表于 2018-12-26 19:24:33 | 显示全部楼层
事件的名字变化了。
我的长按动作一直都还行,不过我都接的网关二代,伴侣就是纯接入,然后现在就是个摆设了。
所有过往,皆为序章。
发表于 2018-12-26 22:15:50 | 显示全部楼层
谢谢分享
GMT+8, 2026-1-2 06:38 , Processed in 0.089477 second(s), 10 queries , MemCached On.
