楼主: 小灰
[基础教程] [GPS定位]Traccar使用教程
发表于 2019-7-15 09:00:19 | 显示全部楼层
simon2137 发表于 2019-7-13 21:03
1.先在mysql中建立一个名为traccar的空数据库以及相应的数据库帐户和密码。
2.在homeassistant的配置文件 ...
谢谢指点
不过 系统在建立相应数据库后 wifi就掉线了  现在插着网线才能用 很多功能用不了 准备这周末重新再刷机看看
发表于 2019-7-18 13:32:46 | 显示全部楼层
还是不行
日志
[13:19:32] INFO: Starting Traccar server...
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/opt/traccar/lib/slf4j-jdk14-1.7.26.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/opt/traccar/lib/logback-classic-1.2.3.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
SLF4J: Actual binding is of type [org.slf4j.impl.JDK14LoggerFactory]
2019-07-18 13:19:33 ERROR: Main method error - Document root element "entry", must match DOCTYPE root "null". - SAXParseException (... < Config:37 < Context:269 < Main:110 < ...)
Exception in thread "main" java.lang.RuntimeException: java.lang.RuntimeException: Configuration file is not a valid XML document
        at org.traccar.Main.run(Main.java:152)
        at org.traccar.Main.main(Main.java:104)
Caused by: java.lang.RuntimeException: Configuration file is not a valid XML document
        at org.traccar.config.Config.<init>(Config.java:52)
        at org.traccar.Context.init(Context.java:269)
        at org.traccar.Main.run(Main.java:110)
        ... 1 more
Caused by: java.util.InvalidPropertiesFormatException: org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 30; Document root element "entry", must match DOCTYPE root "null".
        at sun.util.xml.PlatformXmlPropertiesProvider.load(PlatformXmlPropertiesProvider.java:80)
        at java.util.Properties$XmlSupport.load(Properties.java:1201)
        at java.util.Properties.loadFromXML(Properties.java:881)
        at org.traccar.config.Config.<init>(Config.java:37)
        ... 3 more
Caused by: org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 30; Document root element "entry", must match DOCTYPE root "null".
        at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:203)
        at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.error(ErrorHandlerWrapper.java:134)
        at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:396)
        at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:327)
        at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:284)
        at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.rootElementSpecified(XMLDTDValidator.java:1599)
        at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.handleStartElement(XMLDTDValidator.java:1877)
        at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(XMLDTDValidator.java:742)
        at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1359)
        at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(XMLDocumentScannerImpl.java:1289)
        at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:3132)
        at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:852)
        at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
        at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
        at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:842)
        at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:771)
        at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
        at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(DOMParser.java:243)
        at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:339)
        at sun.util.xml.PlatformXmlPropertiesProvider.getLoadingDoc(PlatformXmlPropertiesProvider.java:106)
        at sun.util.xml.PlatformXmlPropertiesProvider.load(PlatformXmlPropertiesProvider.java:78)
        ... 6 more
[13:19:34] INFO: Starting Traccar server...
发表于 2019-7-18 16:59:26 | 显示全部楼层
代码发出来好像格式乱了,你照附件来改
traccar.rar
715 Bytes, 下载次数: 23
发表于 2019-7-19 11:55:45 | 显示全部楼层
simon2137 发表于 2019-7-18 16:59
代码发出来好像格式乱了,你照附件来改
感谢 日志还是同样错误,我得一点点找找原因了
发表于 2019-7-19 16:41:47 | 显示全部楼层
代码发出来好像格式乱了,你照附件来改
<entry key='database.driver'>com.mysql.cj.jdbc.Driver</entry>
终于搞好,,改了个driver,网上查到不同的版本,名称会有所不同
发表于 2019-7-19 17:15:41 | 显示全部楼层
之前我在N1上发现改不改这个都能连上数据库
发表于 2019-7-20 15:26:31 | 显示全部楼层
这明显欺负我啊。。。
发表于 2020-1-4 17:23:56 | 显示全部楼层
刚刚看到学习
发表于 2020-4-30 17:25:20 | 显示全部楼层
还在调试,一直是离线状态
发表于 2020-9-28 14:57:16 | 显示全部楼层
学习traccar
GMT+8, 2025-9-18 04:21 , Processed in 0.395266 second(s), 11 queries , MemCached On.
