楼主: sunfang1cn
【插件】小米智米电暖气智能版 插件发布
 楼主| 发表于 2019-3-14 17:33:12 | 显示全部楼层
ptlzx 发表于 2019-3-14 11:49
Wed Mar 13 2019 04:04:47 GMT+0800 (CST)
Error loading custom_components.miheater.climate. Make sur ...
我修改了一下,你看看这个版本可不可以用。
 楼主| 发表于 2019-3-14 17:34:19 | 显示全部楼层
Mister_Red 发表于 2019-2-9 19:27
更新到最近版本後顯示插件報錯了
看下我31楼的更新是否可以用
发表于 2019-3-14 21:15:08 | 显示全部楼层
sunfang1cn 发表于 2019-3-14 17:34
看下我31楼的更新是否可以用
错误提示变了:
Thu Mar 14 2019 21:18:27 GMT+0800 (CST)
Error loading custom_components.climate.miheater. Make sure all dependencies are installed
  File "/config/custom_components/climate/miheater.py", line 11, in <module>
    from homeassistant.components.climate import (ClimateDevice, DOMAIN, PLATFORM_SCHEMA, STATE_HEAT,STATE_COOL,SUPPORT_TARGET_TEMPERATURE,SUPPORT_ON_OFF, SUPPORT_OPERATION_MODE)
ImportError: cannot import name 'STATE_HEAT' from 'homeassistant.components.climate' (/usr/src/app/homeassistant/components/climate/__init__.py)
  File "/usr/src/app/homeassistant/loader.py", line 166, in _load_file
    module = importlib.import_module(path)
  File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
  File "<frozen importlib._bootstrap>", line 983, in _find_and_load
  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 728, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/config/custom_components/climate/miheater.py", line 13, in <module>
    from homeassistant.components.climate.const import (ClimateDevice, DOMAIN, PLATFORM_SCHEMA, STATE_HEAT,STATE_COOL,SUPPORT_TARGET_TEMPERATURE,SUPPORT_ON_OFF, SUPPORT_OPERATION_MODE)
ImportError: cannot import name 'ClimateDevice' from 'homeassistant.components.climate.const' (/usr/src/app/homeassistant/components/climate/const.py)
Unable to find platform miheater.
大神再看看,谢谢啦!
发表于 2019-3-16 07:04:05 | 显示全部楼层
大神,31楼的插件在89.1运行还是不行,有错误,信息在33楼,能在看看吗?谢谢啊!
 楼主| 发表于 2019-3-17 15:47:11 | 显示全部楼层
ptlzx 发表于 2019-3-16 07:04
大神,31楼的插件在89.1运行还是不行,有错误,信息在33楼,能在看看吗?谢谢啊! ...
31楼的文件我重新更新了,你再下载试试,不好意思家里目前没时间升级到新版本,所以自己没法测试
发表于 2019-3-17 20:19:25 | 显示全部楼层
sunfang1cn 发表于 2019-3-17 15:47
31楼的文件我重新更新了,你再下载试试,不好意思家里目前没时间升级到新版本,所以自己没法测试 ...
还是有问题,错误信息如下:
Sun Mar 17 2019 20:20:49 GMT+0800 (CST)
Error loading custom_components.miheater.climate. Make sure all dependencies are installed
  File "/config/custom_components/miheater/climate.py", line 11, in <module>
 楼主| 发表于 2019-4-4 23:18:46 | 显示全部楼层
ptlzx 发表于 2019-3-17 20:19
还是有问题,错误信息如下:
我家里今天升级了0.91.0,修改了一个版本,已经可以用了,你去顶楼我原帖底部下载即可。
发表于 2019-4-5 07:13:14 | 显示全部楼层
sunfang1cn 发表于 2019-4-4 23:18
我家里今天升级了0.91.0,修改了一个版本,已经可以用了,你去顶楼我原帖底部下载即可。 ...
谢楼主,可以了。感谢
发表于 2019-8-7 17:11:36 | 显示全部楼层
96.5 又不行了。
发表于 2019-10-30 18:21:56 | 显示全部楼层
HA版本0.100.3,参考:https://github.com/sunfang1cn/homeassistant-mi-heater 操作
下载miheater2.py并拷贝到homeassistant/custom_components/climate/下
configuration.yaml内容如下:
climate:
  - platform: miheater2
    host: 192.168.1.116
    token: a6db04e3c97a838f31346cabb39a92b9
日志:
Platform error: climate - Integration 'miheater2' not found.
HB下使用homebridge-mi-heater插件加入homekit正常
GMT+8, 2025-12-29 16:21 , Processed in 1.590906 second(s), 7 queries , MemCached On.
