查看: 6949|回复: 1
[求助] InfluxDB配置出错,请求老司机出手相助,非常感谢!
aaa
34
发表于 2018-12-23 20:00:06 | 显示全部楼层 |阅读模式
运行环境
raspberry pi+docker+hass
主配置下添加
influxdb:
报错信息
日志 1
Setup failed for influxdb: Component failed to initialize.Setup failed for influxdb: Component failed to initialize.Database host is not accessible due to 'HTTPSConnectionPool(host='localhost', port=8086): Max retries exceeded with url: /write?db=home_assistant (Caused by SSLError(SSLError(1, '[SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:841)'),))', please check your entries in the configuration file (host, port, etc.) and verify that the database exists and is READ/WRITE
日志 2
Setup failed for influxdb: CSetup failed for influxdb: Component failed to initialize.omponent failed to initialize.
PS:没等到老司机,自己解决了
发表于 2018-12-24 00:14:39 | 显示全部楼层
  "log_level": "info",
  "auth": false,
  "ssl": false,
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem"
GMT+8, 2025-11-7 05:03 , Processed in 0.217670 second(s), 7 queries , MemCached On.
