查看: 5889|回复: 7
[求助] github的配置文件怎么更新到本地
发表于 2018-12-18 18:18:01 | 显示全部楼层 |阅读模式
看到这边写了已经加入智睿的彩色控制
但是请问这个配置文件怎么更新到本地呀,已经把HA更新到最新版本了
先谢过啦!
发表于 2018-12-18 21:54:31 | 显示全部楼层
按照上面的路径把PY文件放在custom_components文件夹里面的light文件夹里面,没有这两个文件夹请自己建立
 楼主| 发表于 2018-12-19 02:33:04 | 显示全部楼层
搞了好久,还重装了HASS,现在试了很多遍,还是出现问题,一旦把PY文件放到custom_components/light路径里面,就会连灯都看不到
LOG如下
Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/discovery.py", line 161, in async_load_platform
    hass, component, hass_config)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 45, in async_setup_component
    return await setup_tasks[domain]  # type: ignore
  File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 56, in async_setup_component
    return await task  # type: ignore
  File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 118, in _async_setup_component
    conf_util.async_process_component_config(hass, config, domain)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/config.py", line 763, in async_process_component_config
    platform = get_platform(hass, domain, p_name)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/loader.py", line 60, in get_platform
    return get_component(hass, PLATFORM_FORMAT.format(domain, platform))
  File "/usr/local/lib/python3.6/site-packages/homeassistant/loader.py", line 92, in get_component
    module = importlib.import_module(path)
  File "/usr/local/lib/python3.6/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 994, in _gcd_import
  File "<frozen importlib._bootstrap>", line 971, in _find_and_load
  File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 674, in exec_module
  File "<frozen importlib._bootstrap_external>", line 781, in get_code
  File "<frozen importlib._bootstrap_external>", line 741, in source_to_code
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/config/custom_components/light/xiaomi_miio.py", line 7
    <!DOCTYPE html>
SyntaxError: invalid syntax
流水无味
灌水之王
发表于 2018-12-19 10:01:44 | 显示全部楼层
友情帮顶
我也想学 github更新而ha没更新的东西是否可以直接替换ha里面的文件?
 楼主| 发表于 2018-12-19 12:26:35 | 显示全部楼层
xieahui 发表于 2018-12-19 10:01
友情帮顶
我也想学 github更新而ha没更新的东西是否可以直接替换ha里面的文件? ...
应该是要放到我上面说的自定义文件夹里面的
流水无味
灌水之王
发表于 2018-12-19 12:36:40 | 显示全部楼层
你那都出错了
 楼主| 发表于 2018-12-19 13:19:00 | 显示全部楼层
我也不懂是哪儿出错,翻了好多老外的同样的错误,好像都没解决办法。。
我现在只要移除custom_components这个文件夹,就一切恢复正常,否则只要调用xiaomi_miio的设备都会消失
 楼主| 发表于 2018-12-19 20:23:58 | 显示全部楼层
问题已解决,就简单的创建上述文件夹,将PY文件放进去就OK了
之前是我从GITHUB上下的文件搞错了。
GMT+8, 2025-11-7 05:01 , Processed in 0.789547 second(s), 6 queries , MemCached On.
