楼主: C.Soult
[插件集成] (07/09)Broadlink插排MP1/鸿雁IHC8340B wifi排插 HA支持插件 支持0.73版
发表于 2017-8-28 21:06:55 | 显示全部楼层
我的出现下面的错误提示,请问要如何处理?
2017-08-28 21:05:03 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.switch.broadlink_mp1. Make sure all dependencies are installed
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/loader.py", line 142, in get_component
    module = importlib.import_module(path)
  File "/usr/lib/python3.5/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 986, in _gcd_import
  File "<frozen importlib._bootstrap>", line 969, in _find_and_load
  File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 673, in exec_module
  File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/switch/broadlink_mp1.py", line 19, in <module>
    from broadlink import mp1 as BroadlinkMP1Device
ImportError: No module named 'broadlink'
2017-08-28 21:05:03 ERROR (MainThread) [homeassistant.loader] Unable to find component switch.broadlink_mp1
发表于 2017-8-29 12:06:13 | 显示全部楼层
测试成功,谢谢!!
发表于 2017-8-30 11:06:21 | 显示全部楼层
不知道能不能支持鸿雁带USB的那款
嗯哼,有论坛签名了
发表于 2017-8-31 14:53:47 | 显示全部楼层
LaunchTomorrow 发表于 2017-8-30 11:06
不知道能不能支持鸿雁带USB的那款
亲测可以支持 鸿雁 小优  ICH8334B USB计量版 , 附带一个 鸿雁小优各版本型号与商品名对照表
发表于 2017-8-31 14:56:37 | 显示全部楼层
安装过程  需要python-broadlink的依赖问题需要得到解决
git clone [url]https://github.com/mjg59/python-broadlink.git[/url]
cd python-broadlink
sudo python setup.py install
参见
https://home-assistant.io/components/switch.broadlink/
Install python-broadlink library:
发表于 2017-9-2 21:51:30 | 显示全部楼层
ha 安装后,重启,后台有显示,状态也可以设置,但是硬件没有反应是什么问题呢?IP和MAC都对,是不是HA安装后,还要重新跑一遍易控的操作?
发表于 2017-9-4 11:22:43 | 显示全部楼层
俊客 发表于 2017-9-2 21:51
ha 安装后,重启,后台有显示,状态也可以设置,但是硬件没有反应是什么问题呢?IP和MAC都对,是不是HA安装 ...
看日志看日志看日志看日志看日志
发表于 2017-9-6 23:34:25 | 显示全部楼层
hass.io如何安装啊?
发表于 2017-9-6 23:54:49 | 显示全部楼层
谢谢!@Jones
发表于 2017-9-7 06:22:55 | 显示全部楼层
谢谢分享。
GMT+8, 2026-1-12 00:39 , Processed in 1.792505 second(s), 20 queries , MemCached On.
