查看: 6535|回复: 6
[技术探讨] 刷了OpenMQTTGateway之后
发表于 2018-12-14 16:43:21 | 显示全部楼层 |阅读模式
按着前辈 @671792320 https://bbs.hassbian.com/forum.php?mod=viewthread&tid=894 编译没刷成功,
一直提示
Arduino:1.8.7 (Windows 7), 开发板:"NodeMCU 0.9 (ESP-12 Module), 80 MHz, Flash, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 9600"
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Users\Administrator\AppData\Local\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Users\Administrator\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries D:\我的文档\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcu:CpuFrequency=80,VTable=flash,FlashSize=4M1M,LwIPVariant=v2mss536,Debug=Disabled,DebugLevel=None____,FlashErase=none,UploadSpeed=9600 -ide-version=10807 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_595775 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_262178 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.13 -prefs=runtime.tools.esptool-0.4.13.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.13 -prefs=runtime.tools.mkspiffs.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.2.0 -prefs=runtime.tools.mkspiffs-0.2.0.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.2.0 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.xtensa-lx106-elf-gcc-1.20.0-26-gb404fb9-2.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose F:\360Downloads\raspberry\mqtt\OpenMQTTGateway\OpenMQTTGateway.ino
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Users\Administrator\AppData\Local\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Users\Administrator\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries D:\我的文档\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcu:CpuFrequency=80,VTable=flash,FlashSize=4M1M,LwIPVariant=v2mss536,Debug=Disabled,DebugLevel=None____,FlashErase=none,UploadSpeed=9600 -ide-version=10807 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_595775 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_262178 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.13 -prefs=runtime.tools.esptool-0.4.13.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.13 -prefs=runtime.tools.mkspiffs.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.2.0 -prefs=runtime.tools.mkspiffs-0.2.0.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.2.0 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.xtensa-lx106-elf-gcc-1.20.0-26-gb404fb9-2.path=C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose F:\360Downloads\raspberry\mqtt\OpenMQTTGateway\OpenMQTTGateway.ino
Using board 'nodemcu' from platform in folder: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2
Using core 'esp8266' from platform in folder: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2
Detecting libraries used...
"C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.4.2/tools/sdk/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.4.2/tools/sdk/lwip2/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.4.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_595775/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DARDUINO=10807 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_NODEMCU"" -DESP8266 "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.4.2\\cores\\esp8266" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.4.2\\variants\\nodemcu" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_595775\\sketch\\OpenMQTTGateway.ino.cpp" -o nul
"C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.4.2/tools/sdk/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.4.2/tools/sdk/lwip2/include" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.4.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_595775/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DARDUINO=10807 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_NODEMCU"" -DESP8266 "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.4.2\\cores\\esp8266" "-IC:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.4.2\\variants\\nodemcu" "-ID:\\鎴戠殑鏂囨。\\Documents\\Arduino\\libraries\\PubSubClient\\src" "C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\arduino_build_595775\\sketch\\OpenMQTTGateway.ino.cpp" -o nul
OpenMQTTGateway:61:25: error: ArduinoJson.h: No such file or directory
 #include <ArduinoJson.h>
compilation terminated.
使用 2.7  版本的库 PubSubClient 在文件夹: D:\我的文档\Documents\Arduino\libraries\PubSubClient
exit status 1
所以直接简化,直接下载 https://github.com/1technophile/ ... Gateway.ino.bin.zip
通过esptool 刷入,按一下RST 出现 OpenMQTTGateway的热点,连接
密码为your_password
但是,,,获取到IP后,,浏览器输入ip,显示  网页无法访问, 不知道怎么用了
查了下官方wiki,没找到怎么像espeasy那样进入固件设置之类的~~难道没这个界面吗。。。哈哈
发表于 2018-12-14 21:14:19 | 显示全部楼层
配网的时候有吗?连上之后没有web界面
还是自己编译吧,直接改配置文件,OpenMQTTGateway编译环境很好搭
 楼主| 发表于 2018-12-17 10:59:28 | 显示全部楼层
killadm 发表于 2018-12-14 21:14
配网的时候有吗?连上之后没有web界面
还是自己编译吧,直接改配置文件,OpenMQTTGateway编译环境很好搭 ...
'GICABLE_BITS' was not declared in this scope
这个变量得在哪里给他定义下呢?
发表于 2018-12-17 18:18:03 | 显示全部楼层
这个变量得在哪里给他定义下呢?
库用lib文件夹下的
发表于 2018-12-17 19:43:14 | 显示全部楼层
OpenMQTTGateway 这玩意儿现在又web了吗?几个月之前刷还是没有的,通过wiki看文档配置好yaml就可以接收到mqtt的信息了
 楼主| 发表于 2018-12-19 16:26:45 | 显示全部楼层
killadm 发表于 2018-12-17 18:18
库用lib文件夹下的
谢谢K大  可以了
发表于 2020-1-31 19:04:32 | 显示全部楼层
我也发现这问题了,好像这货的调试输出在串口里.没有web
GMT+8, 2025-12-31 17:29 , Processed in 1.648564 second(s), 11 queries , MemCached On.
