查看: 4612|回复: 7
HA提示这些错误, 是什么问题
发表于 2018-12-9 18:23:05 | 显示全部楼层 |阅读模式
Error doing job: Task exception was never retrievedTraceback (most recent call last):  File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 335, in _async_add_entity    'Invalid entity id: {}'.format(entity.entity_id))homeassistant.exceptions.HomeAssistantError: Invalid entity id: automation.
之前有用到Template, 提示这个错误后就不起作用了
发表于 2018-12-10 07:16:31 | 显示全部楼层
Invalid entity id: automation.自动化有错误
 楼主| 发表于 2018-12-10 09:39:44 | 显示全部楼层
以前一直挺好的, 代码也没有改过, 只是升级了HA, 目前是用来控制暖气片的自动化不工作了
调节暖气片温度设定滑杆, 当室内温度达到设定值 关闭暖气片的电子水阀, 反之则打开,  去年冬天设置好后, 整个冬天天然气节省好多
下面是代码, 当时写的, 可能是HA升级后, 语法格式变了, 现在设置后不能自动打开开关了
input_number:
  guestroom_warmer_set_temp:
    icon: mdi:thermometer-lines
    initial: 16
    min: 5
    max: 20
    step: 0.10
  - platform: template
    sensors:
      guestroom_warmer_set_temp_show:
        friendly_name: '设定的温度'
        unit_of_measurement: "°C"
        value_template: '{{states.input_number.guestroom_warmer_set_temp.state|round(0.00)}}'
automation:
  - id: guestroom_warmer_off_temp
    alias: guestroom_warmer_off_temp
    trigger:
        value_template: "{% if states.sensor.temperature_158d00019cb884.state|round(0.00) >= states.input_number.guestroom_warmer_set_temp.state|round(0.00)%} true {% endif %}"
    action:
      service: switch.turn_off
      entity_id: switch.guestroom_warmer
  - id: guestroom_warmer_on_temp
    alias: guestroom_warmer_on_temp
    trigger:
        value_template: "{% if states.sensor.temperature_158d00019cb884.state|round(0.00) < states.input_number.guestroom_warmer_set_temp.state|round(0.00)%} true {% endif %}"
    action:
      service: switch.turn_on
group:
  myhome:
    view: yes
    entities:
      - group.guestroom
 guestroom:
    view: no
    entities:
      - switch.guestroom_warmer
      - input_number.guestroom_warmer_set_temp
      - sensor.guestroom_warmer_set_temp_show
      - sensor.temperature_158d00019cb884
      - sensor.humidity_158d00019cb884
t.yaml
1.54 KB, 下载次数: 0
发表于 2018-12-10 10:45:32 | 显示全部楼层
自动化在ui界面里重写一遍,或者用node red,自动化的话nodered更好用一点
 楼主| 发表于 2018-12-10 12:33:00 | 显示全部楼层
在UI里重写是把 自动化 放到 automations.yaml 中吗?
nodered 还不会, 接下来研究一下
发表于 2018-12-10 12:40:51 | 显示全部楼层
nodered 还不会, 接下来研究一下 ...
配置里有个自动化编辑器,用那个重写一下
 楼主| 发表于 2018-12-10 14:40:58 | 显示全部楼层
roots 发表于 2018-12-10 12:40
配置里有个自动化编辑器,用那个重写一下
好的, 已经重新在UI的编辑器里 写的, 的确有的数据服务里是{} 空的, 把内容填好了,
比之前好一点了, 有时设定后会触发, 但不是每次都行, 我到时还是想想怎么用NODERED
发表于 2018-12-10 14:43:12 | 显示全部楼层
比之前好一点了, 有 ...
Node-Red的触发比automations组件好用
GMT+8, 2026-1-2 10:40 , Processed in 1.607354 second(s), 11 queries , MemCached On.
