查看: 9948|回复: 2
[进阶教程] 【六神分享】博联S1C抛弃Homebridge转战原生Homekit
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-12-7 10:49:28 | 显示全部楼层 |阅读模式
以前一直用homebridge因为手头有个S1C 监控着我的车库,一直在用S1C的homebridge插件,所以很久没有停掉,懒癌晚期不想折腾导致一直没处理这个问题,
但是其他插件都被原生HK代替了,只剩下这一个 感觉有点鸡肋,
最终强迫症战胜了懒癌,开始动手解决它。
因为S1C的HA插件貌似作者有地方定义写错了,门磁传感器在HK中并不显示,简单研究了下,重新定义了一个binary_sensor 屏蔽掉原来的,就可以了。
简单配置:
cover:
  #窗帘射频模块@zorankeinfo修改版
  - platform: rm_cover
  #窗帘射频模块@roiff
  # - platform: broadlink
    host: !secret blrm_host
    mac: !secret blrm_mac
    covers:
      garage_east:
        travel_time: 8
        # position_sensor: sensor.broadlink_s1c_东车库门磁
        command_open: 'sgCcAAolCyUlCyQLJQolCwolCiYlCgomJQoKJgolJQslCgomCiUlCiULJQsKJQolCiYlCgwAAVAKJQslJQolCyULJAsKJgkmJQoK'
        command_close: 'sgCGAAskCyQkCyMMIwwjCwskCyQkCwolIwwKJQokJAskCwskCiUjDCMMIwskCwskCyQKJAwAAVAKJQokJAskCyQLJAsKJQolIws'
        command_stop: 'sgCiACULCyUkCwskCyQMAAFQCiUKJSULJAslCyQLCyUKJSQLCyUkCwslCiUkCyULCyQLJSQLJQolCwskJQsKJQskDAABUAolCiUkDCQLJAslCwolCyUk'
  - platform: template
    covers:
      gd_east_temp:
        friendly_name: '东车库门'
        value_template: "{% if not is_state('sensor.broadlink_s1c_东车库门磁', 'closed') %}open{% else %}closed{% endif %}"
        open_cover:
          service: script.turn_on
          entity_id: script.garage_east_open
        close_cover:
          entity_id: script.garage_east_close
        stop_cover:
          service: cover.stop_cover
          entity_id: cover.garage_east
        icon_template: "{% if not is_state('sensor.broadlink_s1c_东车库门磁', 'closed') %}mdi:garage-open{% else %}mdi:garage{% endif %}"
binary_sensor:
    sensors:
      movement_1:
        device_class: motion
        value_template: "{{ is_state('sensor.broadlink_s1c_东车库红外', 'motion_detected') }}"
      door_1:
        device_class: opening
        value_template: "{{ is_state('sensor.broadlink_s1c_东车库门磁', 'open') }}"
automation:
  - alias: Garage_Open_East
    initial_state: false
    trigger:
    - platform: state
      entity_id: cover.gd_east_temp
      to: 'open'
    action:
    - service: hello_miai.force_send
    # - service: tts.baidu_say
      # entity_id: media_player.mopidy,media_player.kodi5
      data_template:
        message: "东边车库门被打开。"
        # cache: false
  - alias: Garage_Closed_East
    trigger:
    - platform: state
      to: 'closed'
    action:
      data_template:
        message: "东边车库门已关上。"
        # cache: false
group:
  EastGD:
    view: no
    entities:
      - cover.garage_east
      - cover.gd_east_temp
      - binary_sensor.movement_1
      - binary_sensor.door_1
      - sensor.broadlink_s1c_遥控器
      - script.garage_east_open
      - script.garage_east_close
homeassistant:
  customize:
    cover.garage_east:
      friendly_name: 东车库门
      homebridge_name: 车库东门
      hidden: true
      homebridge_cover_type: garage_door
      device_class: garage
      initial_state: 'off'
    cover.gd_east_temp:
    sensor.broadlink_s1c_东车库红外:
      hidden: true
    sensor.broadlink_s1c_东车库门磁:
      hidden: true
    binary_sensor.movement_1:
      friendly_name: 东车库移动检测
    binary_sensor.door_1:
      friendly_name: 东车库门状态
发表于 2022-9-23 08:54:00 | 显示全部楼层
大佬你的 s1c 还在用吗?
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2022-10-15 19:31:05 | 显示全部楼层
wpl820213 发表于 2022-9-23 08:54
大佬你的 s1c 还在用吗?
不在用了,这个不是特别准确,现在改成了 用esp模块硬改车库控制器,然后通过esphome做配置了. 把车库控制器的几个触电和esp模块的继电器焊接,然后控制就相当于直接点按车库控制器上的按键一个道理了
GMT+8, 2026-1-18 08:03 , Processed in 0.150983 second(s), 7 queries , MemCached On.
