查看: 5799|回复: 2
[求助] 新手win7 hass启动问题,Unkno wn service discovered
发表于 2018-12-5 00:56:12 | 显示全部楼层 |阅读模式
按官网步骤在windows上安装python3和homeassistant,安装都成功了,最后执行 hass --open-ui 的时候,执行到下面步骤时就一直卡住了,1个多小时都没动,这是怎么回事呢,请大神指教一下,win7系统
2018-12-05 00:28:52 INFO (MainThread) [homeassistant.core] Starting Home Assista
nt
2018-12-05 00:28:52 INFO (MainThread) [homeassistant.core] Timer:starting
2018-12-05 00:29:05 INFO (MainThread) [homeassistant.components.discovery] Unkno
wn service discovered: igd {'host': '192.168.0.1', 'port': xxxx, 'ssdp_descripti
on': 'http://192.168.0.1:xxxx/igd.xml', 'name': 'Wireless N Router WRxxxN', 'mod
el_name': 'TL-WRxxxN', 'model_number': '2.0', 'serial': None, 'manufacturer': 'T
P-LINK', 'udn': 'uuid:xxxx-xxxxxxxxxxxxxxxxxxxxx-xxxxxxxxxxxx', 'upnp_device_typ
e': 'urn:xxxxxx-xxxx-org:device:xxxxxxxxxxxxxxxxxxxx:x'}
发表于 2018-12-5 21:06:24 来自手机 | 显示全部楼层
试试hass,  我之前也是hass --open-ui不能进!
 楼主| 发表于 2018-12-7 17:59:05 | 显示全部楼层
直接敲hass,情况一样还是卡住,不过这个时候我打开一个网页,输入http://127.0.0.1:8123, homeassistant的页面就出来了,这个算成功了吗?
GMT+8, 2025-12-15 23:59 , Processed in 0.057277 second(s), 13 queries , MemCached On.
