查看: 8419|回复: 7
[求助] 【求教:不胜感谢】树莓派hassbian系统安装运行homebridge出错
发表于 2018-12-5 00:00:09 | 显示全部楼层 |阅读模式
求教:不胜感谢
hassbian 安装运行homebridge错误
pi@hassbian:~/.homebridge $ homebridge
[2018-12-4 15:33:14] Loaded config.json with 0 accessories and 1 platforms.
[2018-12-4 15:33:14] ---
[2018-12-4 15:33:15] Loaded plugin: homebridge-homeassistant
[2018-12-4 15:33:15] Registering platform 'homebridge-homeassistant.HomeAssistant'
[2018-12-4 15:33:15] ---
[2018-12-4 15:33:15] Loading 1 platforms...
[2018-12-4 15:33:15] [HomeAssistant] Initializing HomeAssistant platform...
[2018-12-4 15:33:15] [HomeAssistant] Fetching HomeAssistant devices.
[2018-12-4 15:33:15] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
config.json
    "bridge": {
        "name": "HomeKit",
        "username": "B8:27:EB1:46:1F", #我的树莓派mac地址
        "port": 51826,
        "pin": "123-45-678"
    "platforms": [
    "platform": "HomeAssistant",
    "name": "HomeAssistant",
    "host": "http://192.168.2.37:8123", #我的树莓派IP地址
    "password": "raspberry",
    "supported_types": ["binary_sensor","cover","fan","garage_door","input_boolean","light","lock","media_player","rollershutter","scene","sensor","switch","climate","script","automation"],
    "default_visibility": "visible"
homeassistant 可以网页登陆,创建的用户名是HomeAssistant 密码是 raspberry
发表于 2018-12-5 08:10:34 | 显示全部楼层
用自带的homekit就可以了
发表于 2018-12-5 08:35:06 | 显示全部楼层
现在高版本的hassbian度自带homekit支持了,不必再折腾homebridge了,直接config文件中添加
发表于 2018-12-11 01:44:11 | 显示全部楼层
同样的问题 咋搞
发表于 2019-1-7 16:03:03 | 显示全部楼层
xthncn 发表于 2018-12-5 08:35
现在高版本的hassbian度自带homekit支持了,不必再折腾homebridge了,直接config文件中添加 ...
那么米家空气净化器,怎么搞,就显示个风扇,一点不智能
发表于 2019-1-7 22:16:34 | 显示全部楼层
没有用哪个东西,是不是也可以接入米家网关统一管理呢?
发表于 2019-1-8 23:16:04 | 显示全部楼层
WiFi的。。。
发表于 2019-1-13 16:32:19 | 显示全部楼层
Aiden1 发表于 2018-12-5 08:10
用自带的homekit就可以了
人家就是不想用自带的,自带的不能hb上看摄像头和小米网管报警,功能受限
GMT+8, 2025-12-24 11:15 , Processed in 0.440156 second(s), 13 queries , MemCached On.
