查看: 2657|回复: 0
[求助] 证书错误求助!
发表于 2018-12-4 19:41:07 | 显示全部楼层 |阅读模式
Error doing job: SSL handshake failed
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午7:32 /usr/src/app/homeassistant/core.py (ERROR)
Error doing job: SSL error errno:1 reason: UNSUPPORTED_PROTOCOL
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]Log Details (ERROR)Tue Dec 04 2018 19:39:03 GMT+0800 (中国标准时间)
Error doing job: SSL error errno:1 reason: UNSUPPORTED_PROTOCOLTraceback (most recent call last):  File "uvloop/sslproto.pyx", line 504, in uvloop.loop.SSLProtocol.data_received  File "uvloop/sslproto.pyx", line 204, in uvloop.loop._SSLPipe.feed_ssldata  File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata  File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake    self._sslobj.do_handshake()ssl.SSLError: [SSL: UNSUPPORTED_PROTOCOL] unsupported protocol (_ssl.c:841)
Error doing job: SSL handshake failedTraceback (most recent call last):  File "uvloop/handles/stream.pyx", line 609, in uvloop.loop.UVStream._on_eof  File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata  File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake    self._sslobj.do_handshake()ssl.SSLError: [SSL: UNSUPPORTED_PROTOCOL] unsupported protocol (_ssl.c:841)
GMT+8, 2025-12-24 11:20 , Processed in 1.167882 second(s), 4 queries , MemCached On.
