查看: 7697|回复: 2
[求助] 小米净水器加入homebridge和HASS出问题,请大神指点。
发表于 2018-12-2 16:14:17 | 显示全部楼层 |阅读模式
环境:群晖docker上homebridge、HASS 0.83.2
HASS 0.83.2方式 参考【https://github.com/bit3725/homeassistant-mi-water-purifier
拷贝mi_water_purifier.py到custom_components/sensor目录下,按上面参考帖编辑configuration.yaml文件内容,但启动HASS状态里找不到净水器,错误信息:
群晖docker下的hass里怎么安装python-miio,不知道是不是这个原因?
Sun Dec 02 2018 16:10:20 GMT+0800 (CST)
Error while setting up platform mi_water_purifier
  File "/config/custom_components/sensor/mi_water_purifier.py", line 159, in parse_data
    status = self._device.send('get_prop', [])
  File "/usr/local/lib/python3.6/site-packages/miio/device.py", line 263, in send
    self.__id = m.data.value["id"]
TypeError: 'NoneType' object is not subscriptable
  File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
    return fut.result()
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/config/custom_components/sensor/mi_water_purifier.py", line 34, in setup_platform
    waterPurifier = XiaomiWaterPurifier(device, name)
  File "/config/custom_components/sensor/mi_water_purifier.py", line 116, in __init__
    self.parse_data()
  File "/config/custom_components/sensor/mi_water_purifier.py", line 177, in parse_data
    except DeviceException:
NameError: name 'DeviceException' is not defined
unable to parse json '{"result":[net],"id":1}': Expecting value: line 1 column 12 (char 11)
直接加入homebridge方式 https://www.npmjs.com/package/homebridge-mi-water-purifier
运行一半出错停止
install.sh
#!/bin/bash
apt-get install libavahi-compat-libdnssd-dev
npm install -g homebridge-mi-aqara
npm install -g homebridge-yeelight
npm install -g homebridge-synology
npm install -g miio
npm install -g homebridge-mqtt-switch-tasmota
npm install -g miio homebridge-mi-ir-remote
npm install -g homebridge-mi-acpartner
npm install -g miio homebridge-mi-water-purifier
config.json
"platforms": [{
    "platform": "MiWaterPurifierPlatform",
    "deviceCfgs": [{
        "type": "MiWaterPurifier",
        "ip": "192.168.31.x",
        "token": "xxxxxxxxxxxxxxxxxxx",
        "Name": "Water TDS"
发表于 2019-2-15 11:58:22 | 显示全部楼层
楼主 解决问题了吗?请教一下你。
 楼主| 发表于 2019-2-18 11:48:07 | 显示全部楼层
wangyiyuan 发表于 2019-2-15 11:58
楼主 解决问题了吗?请教一下你。
不支持1A好像,要6个过滤棒的才行。
GMT+8, 2025-12-24 09:20 , Processed in 0.498916 second(s), 5 queries , MemCached On.
