楼主: wudijushi
[教程系列] 【分享】【Node-Red】【网易云音乐】登录播放个人歌单
发表于 2019-1-10 22:25:06 | 显示全部楼层
Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 279, in _handle_service_platform_call
    await func(entity, data)
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/media_player/mpd.py", line 312, in play_media
    self._client.load(media_id)
  File "/usr/local/lib/python3.6/site-packages/mpd/base.py", line 381, in mpd_command
    return wrapper(self, name, args, callback)
  File "/usr/local/lib/python3.6/site-packages/mpd/base.py", line 473, in _execute
    return retval()
  File "/usr/local/lib/python3.6/site-packages/mpd/base.py", line 368, in command_callback
    res = function(self, self._read_lines())
  File "/usr/local/lib/python3.6/site-packages/mpd/base.py", line 311, in _parse_nothing
    for line in lines:
  File "/usr/local/lib/python3.6/site-packages/mpd/base.py", line 538, in _read_lines
    line = self._read_line()
  File "/usr/local/lib/python3.6/site-packages/mpd/base.py", line 527, in _read_line
    raise CommandError(error)
mpd.base.CommandError: [50@0] {load} No such playlist
楼主,我可以点歌,也能获取歌单,但是播放不了歌单歌曲,一按就报错,树霉派+docker+hassio0.84.6+mpd我查看了nodered,也获取到歌单了
 楼主| 发表于 2019-1-11 10:55:59 | 显示全部楼层
ufonba 发表于 2019-1-10 22:25
[code]Error doing job: Task exception was never retrieved
Traceback (most recent ca ...
No such playlist,你看看node-red生成的歌单URL在浏览器能否访问
发表于 2019-1-11 10:56:48 | 显示全部楼层
我看了,生成的URL可以访问
 楼主| 发表于 2019-1-11 10:58:06 | 显示全部楼层
ufonba 发表于 2019-1-11 10:56
我看了,生成的URL可以访问
检查下node-red初始化参数配置是否填写信息有问题
发表于 2019-1-11 11:15:38 | 显示全部楼层
应该没有错,因为可以点歌成功了,也获取到歌单
发表于 2019-1-11 11:59:19 | 显示全部楼层
我可以访问
http://red-node_IP/my_songs.m3u
我拉了层主树霉派的镜像,不知道是不是这个原因
发表于 2019-1-13 21:57:16 | 显示全部楼层
大神666!
发表于 2019-1-14 10:13:19 | 显示全部楼层
  "entity_id": "media_player.mpd",
"media_content_id":"http://192.168.1.110:1880/my_songs.m3u",
"media_content_type":"playlist"
我直接服务里用,也是出现相同的错误,是不是我的MPD的问题?我用的是树霉派+0.84.6+hass.io+mopidy
楼主用的是什么播放器?
我将my_songs.m3u下载下来,放到目录里,改成
"media_content_id":"my_songs",
是可以播放的
 楼主| 发表于 2019-1-14 12:15:51 | 显示全部楼层
ufonba 发表于 2019-1-14 10:13
[code]{
"media_content_id":"http://192.168.1. ...
你进入hass  shell环境试试ping 192.168.1.110这个地址,我觉得网络问题的可能性比较高
发表于 2019-1-15 09:59:02 | 显示全部楼层
wudijushi 发表于 2019-1-14 12:15
你进入hass  shell环境试试ping 192.168.1.110这个地址,我觉得网络问题的可能性比较高 ...
会不会是因为没开SSL的原因,所以在hass里访问不了这个链接NODERED
GMT+8, 2025-12-22 19:03 , Processed in 1.508885 second(s), 6 queries , MemCached On.
