楼主: JACK潘
[教程系列] 关于『Node-RED』配置安装方面的问题总结
发表于 2022-2-9 16:12:13 | 显示全部楼层
厉害厉害,感谢分享。
发表于 2022-4-1 22:21:42 来自手机 | 显示全部楼层
还是打不开网页,打开是502提示
发表于 2022-6-5 18:15:34 | 显示全部楼层
bfpolicemiaoxin 发表于 2022-4-1 22:21
还是打不开网页,打开是502提示
一樣顯示
502: Bad Gateway
发表于 2022-6-7 11:13:32 | 显示全部楼层
目前好像没看见这个config的设置界面,启动一会儿就自动关闭了,什么问题呢?  ssl关闭了,其余没怎么设置,账号密码都用administrator理论够位数了。重新下了和卸载好几次了,没用,还是运行一下就关闭了。
报警如下,有懂的来看看
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 11.1.2
You are running the latest version of this add-on.
System: Home Assistant OS 8.1  (amd64 / qemux86-64)
Home Assistant Core: 2022.6.2
Home Assistant Supervisor: 2022.05.3
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] customizations.sh: executing...
[cont-init.d] customizations.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] node-red.sh: executing...
[16:28:02] FATAL:
[16:28:02] FATAL: Configuration of this add-on is incomplete.
[16:28:02] FATAL:
[16:28:02] FATAL: Please be sure to set the "credential_secret" option.
[16:28:02] FATAL:
[16:28:02] FATAL: The credential secret is an encryption token, much like
[16:28:02] FATAL: a password, that is used by Node-RED for encrypting
[16:28:02] FATAL: credentials you put into Node-RED.
[16:28:02] FATAL:
[16:28:02] FATAL: Just like a password, a credential secret can be
[16:28:02] FATAL: anything you like. Just be sure to store it somewhere
[16:28:02] FATAL: safe for later, e.g., in case of a recovery.
[16:28:02] FATAL:
[cont-init.d] node-red.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
发表于 2022-10-12 14:16:47 | 显示全部楼层
感谢LZ,成功打开Node_RED
发表于 2022-11-20 11:18:32 | 显示全部楼层
讲的太清楚了,可算把nodered给装上了,感谢楼主!
顺便发表一下感想,感觉论坛好多帖子说的很不详细,作为小白很难按照帖子把hass或者nodered安装好。
论坛需要楼主这样的,稍微把内容讲详细一些。
发表于 2023-4-22 10:56:32 | 显示全部楼层
感谢楼主分享,终于装上了
 楼主| 发表于 2023-5-13 11:24:54 | 显示全部楼层
发表于 2023-6-13 17:37:26 | 显示全部楼层
费心了,不知道真的很麻烦
发表于 2024-1-15 17:07:59 | 显示全部楼层
guitengyue 发表于 2020-9-17 14:13
感谢lz,这个账号密码我今天尝试了半天。。。原来是ha的账号密码
你这个回复帮了大忙,谢谢了!
GMT+8, 2025-11-2 20:08 , Processed in 0.237465 second(s), 13 queries , MemCached On.
