查看: 6081|回复: 4
[求助] 配置Dlib+安卓手机IPcam,HA连接中断
发表于 2018-11-30 15:25:09 | 显示全部楼层 |阅读模式
在HA中配置了Dlib和安卓手机IPcam,两个一起用的时候HA一直报连接中断,有大神知道原因吗?如果手机端不开启IPcam APP,HA不会断开连接;
如果把image_processing注释掉,使用IPcam的时候HA也不会断开连接,HA上的图像显示正常;
两个一起用的时候,只要手机打开APP,HA就断开连接,然后尝试连接,连上后马上又断开,一直循环
另外,配置dlib_face_identify的时候,会出现下面这种报错,这个又是为什么?
发表于 2018-12-1 08:24:39 | 显示全部楼层
1、断开连接看日志。
2、如果你不是 hassio ,请自行解决 dlib的运行环境问题。
http://dlib.net/
https://bbs.hassbian.com/thread-1604-1-1.html
 楼主| 发表于 2018-12-5 09:56:52 | 显示全部楼层
neroxps 发表于 2018-12-1 08:24
1、断开连接看日志。
断开时候的log如下:
2018-12-05 01:53:57 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=95 from 2018-12-05 01:53:11.059957)
2018-12-05 01:53:58 WARNING (MainThread) [homeassistant.loader] You are using a custom component for switch.pptv which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-12-05 01:53:58 WARNING (MainThread) [homeassistant.loader] You are using a custom component for image_processing.dlib_face_detect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-12-05 01:54:00 ERROR (MainThread) [pydroid_ipcam] Failed to communicate with IP Webcam: Cannot connect to host 192.168.1.108:8080 ssl:None [Connection refused]
2018-12-05 01:54:00 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
2018-12-05 01:54:00 ERROR (SyncWorker_0) [homeassistant.components.notify.ios] The notify.ios platform was loaded but no devices exist! Please check the documentation at https://home-assistant.io/ecosystem/ios/notifications/ for more information
2018-12-05 01:54:05 ERROR (SyncWorker_2) [homeassistant.components.light.yeelight] Failed to connect to bulb 192.168.1.106, Desk Light: Bulb closed the connection.
2018-12-05 01:54:07 ERROR (MainThread) [homeassistant.components.camera.mjpeg] Error getting new camera image: Cannot connect to host 192.168.1.108:8080 ssl:None [Connection refused]
2018-12-05 01:54:11 ERROR (MainThread) [pydroid_ipcam] Failed to communicate with IP Webcam: Cannot connect to host 192.168.1.108:8080 ssl:None [Connection refused]
2018-12-05 01:54:11 ERROR (MainThread) [homeassistant.components.camera.mjpeg] Error getting new camera image: Cannot connect to host 192.168.1.108:8080 ssl:None [Connection refused]
2018-12-05 01:54:11 ERROR (MainThread) [homeassistant.components.image_processing] Error on receive image from entity: Unable to get image
另外我用的是hassio,在hassio下dlib有问题吗?
发表于 2018-12-5 15:43:22 | 显示全部楼层
qqq34242615 发表于 2018-12-5 09:56
断开时候的log如下:
2018-12-05 01:53:57 WARNING (Recorder) [homeassistant.components.recorder] End ...
你的摄像头拒绝你的连接。
 楼主| 发表于 2018-12-5 16:42:33 | 显示全部楼层
你的摄像头拒 ...
但是如果不配置dlib,打开摄像头没问题,连接很正常;配置了dlib一开启摄像头HA就断开连接,就出现报错,这是为什么?
用OpenCV也没问题
GMT+8, 2025-12-24 11:17 , Processed in 0.229802 second(s), 11 queries , MemCached On.
