查看: 20652|回复: 8
[求助] HomeAssistant可以显示小米所有配件,但iphone上只显示小米网关
发表于 2017-7-15 18:58:24 | 显示全部楼层 |阅读模式
HomeAssistant显示界面
HomeAssistant显示界面
config.json配置文件
    "bridge": {
        "name": "Hao's Home",
        "username": "CC:22:3D:E3:CE:30",
        "port": 51926,
        "pin": "198-60-824"
    "platforms": [
                  "platform": "HomeAssistant",
                  "name": "HomeAssistant",
                  "host": "http://192.168.31.172:8123",
                  "password": "raspberry",
                  "supported_types": ["fan", "binary_sensor", "sensor", "garage_door", "input_boolean", "light", "lock", "media_player", "rollershutter", "scene", "switch"]
configuration.yaml配置文件
homeassistant:
  # 智能家庭的名称
  # 经纬度
  latitude: 25.965072
  longitude: 119.623822
  # 海拔
  elevation: 10
  # 度量衡单位制式(metric)是公制,(imperial)是英制
  unit_system: metric
  # 市区
  time_zone: Asia/Shanghai
  customize: !include customize.yaml
# 在网页界面的首页显示简介(那一大段E文),不想看到的话,请在前面加上#号
#introduction:
# 是否使用默认的“首页”
frontend:
# 配置面板
config:
# 给系统网页的登录加上一个密码 (推荐!),先去掉下面这行的#号
http:
  # Uncomment this to add a password (recommended!)
  # api_password: PASSWORD
  # Uncomment this if you are using SSL or running in Docker etc
  # base_url: example.duckdns.org:8123
# 升级提示,当HomeAssitant有新版本发布的时候,“日出日落”图标会变成(Update)字样
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# 如果调用Alexa设备,那么要禁用系统自动发现新设备
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
logbook:
# 太阳“跟踪器”,也就是“日出日落时间”
sun:
# Weather Prediction
  platform: yr
# Text to speech
tts:
  platform: google
group: !include groups.yaml
xiaomi: !include xiaomi.yaml
customize.yaml配置文件
binary_sensor.door_window_sensor_158d00019db6c5:
  friendly_name: 宿舍门
  homebridge_hidden: true
binary_sensor.motion_sensor_158d0000d2b5ad:
  friendly_name: 卫生间人体感应器
binary_sensor.switch_158d0000d4cdad:
  friendly_name: 无线开关1
binary_sensor.switch_158d0001066651:
  friendly_name: 无线开关2
light.gateway_light_34ce008dd05e:
  friendly_name: 小米网关
  homebridge_hidden: false
light.yeelight_white_f0b4290ed8e9:
  friendly_name: 卫生间灯
sensor.humidity_158d0001a2b7da:
  friendly_name: 湿度
sensor.temperature_158d0001a2b7da:
  friendly_name: 温度
groups.yaml配置文件
xiaomi:
  view: no
  entities:
    - binary_sensor.door_window_sensor_158d00019db6c5
    - binary_sensor.motion_sensor_158d0000d2b5ad
    - binary_sensor.switch_158d0000d4cdad
    - binary_sensor.switch_158d0001066651
    - light.gateway_light_34ce008dd05e
    - light.yeelight_white_f0b4290ed8e9
    - sensor.humidity_158d0001a2b7da
    - sensor.temperature_158d0001a2b7da
xiaomi.yaml配置文件
gateways:
  - sid: 34ce008dd05e
    key: 95gz7w4j0xi87287
config.json 配置代码
config.json 配置代码
只发干货
教程狂人论坛风云人物
发表于 2017-7-15 19:38:51 | 显示全部楼层
customize.yaml配置文件里把每一条[homebridge_hidden: true]去掉改成如[homebridge_name: 宿舍门]
重启服务器
 楼主| 发表于 2017-7-15 20:20:18 | 显示全部楼层
重启服 ...
谢谢大神,按你的方法小米温湿度感应器,门窗感应器都可以用,yeelight和人体感应器还是不显示
发表于 2017-7-24 15:10:55 | 显示全部楼层
https://bbs.hassbian.com/thread-626-1-1.html估计和我一样,是更新后的问题
发表于 2017-8-8 16:07:53 | 显示全部楼层
谢谢分享
发表于 2017-8-10 01:06:12 来自手机 | 显示全部楼层
true改false啊,那个意思是是否在hb隐藏
发表于 2017-8-24 12:55:13 | 显示全部楼层
学习中。。。
发表于 2017-9-5 12:34:54 | 显示全部楼层
你给隐藏了怎么显示呢。。,hidden 改成false
禁止发言
发表于 2018-1-4 21:30:42 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-12-25 11:55 , Processed in 0.936441 second(s), 11 queries , MemCached On.
