查看: 6268|回复: 6
[求助] 添加wake_on_lan出现错误
发表于 2018-11-22 14:13:48 | 显示全部楼层 |阅读模式
添加wake_on_lan出现错误,使用0.82.1版本,google无解,请帮忙看看哪里出问题,谢谢。
switch
  - platform: wake_on_lan
    #name: host_Y
    mac_address: "00:E0:4C:97:8C:CE"
    host: "192.168.10.18"
wake_on_lan: Error on device update!Traceback (most recent call last):  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 251, in _async_add_entity    await entity.async_device_update(warning=False)  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 349, in async_device_update    await self.hass.async_add_executor_job(self.update)  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__    yield self  # This tells Task to wait for completion.  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup    future.result()  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result    raise self._exception  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run    result = self.fn(*self.args, **self.kwargs)  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/switch/wake_on_lan.py", line 99, in update    status = sp.call(ping_cmd, stdout=sp.DEVNULL, stderr=sp.DEVNULL)  File "/usr/lib/python3.5/subprocess.py", line 247, in call    with Popen(*popenargs, **kwargs) as p:  File "/usr/lib/python3.5/subprocess.py", line 676, in __init__    restore_signals, start_new_session)  File "/usr/lib/python3.5/subprocess.py", line 1282, in _execute_child    raise child_exception_type(errno_num, err_msg)FileNotFoundError: [Errno 2] No such file or directory: 'ping'
发表于 2018-11-22 14:43:53 | 显示全部楼层
你这个IP写法有问题,详见官方用法。
https://www.home-assistant.io/components/switch.wake_on_lan/
 楼主| 发表于 2018-11-22 15:54:41 | 显示全部楼层
情非殇 发表于 2018-11-22 14:43
你这个IP写法有问题,详见官方用法。
谢谢您的回复,我是按官方写的,出现错误后才胡乱自己尝试,日志错误相同
佑桑
发表于 2018-11-22 18:31:35 | 显示全部楼层
  mac_address: "a8:82:00:36:1c:a0"
  host: "10.59.1.249"
  turn_off:
    service: script.tv_remote_power_off
這是我的, 參考一下
 楼主| 发表于 2018-11-25 11:40:30 | 显示全部楼层
chinyaolin 发表于 2018-11-22 18:31
[code]- platform: wake_on_lan
  mac_address: "a8:82:00: ...
谢谢,问题解决了。
发表于 2019-5-11 13:43:01 | 显示全部楼层
 楼主| 发表于 2019-5-24 16:19:42 | 显示全部楼层
6#正解。
GMT+8, 2025-12-24 05:12 , Processed in 0.481560 second(s), 8 queries , MemCached On.
