查看: 2955|回复: 3
[技术探讨] HA内置MQTT报错,Nodered不能连接,MQTT.fx能连接,何故呢?先...
发表于 2018-11-22 02:36:32 | 显示全部楼层 |阅读模式
About
Path to configuration.yaml: /config
[color=var(--dark-primary-color)]60 Loaded Components
[color=var(--dark-primary-color)]Developed by a bunch of awesome people.
Published under the Apache 2.0 license
Source: [color=var(--dark-primary-color)]server — [color=var(--dark-primary-color)]frontend-ui
Built using [color=var(--dark-primary-color)]Python 3, [color=var(--dark-primary-color)]Polymer, Icons by [color=var(--dark-primary-color)]Google and [color=var(--dark-primary-color)]MaterialDesignIcons.com.
Frontend JavaScript version: latest
[color=var(--dark-primary-color)]Try out the new Lovelace UI (experimental)
>> Set lovelace as default page on this device <<
Invalid connection from (client @=127.0.0.1:51720) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]上午2:31 util/async_.py (ERROR)
Invalid connection from (client @=127.0.0.1:51710) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=127.0.0.1:51701) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=127.0.0.1:51693) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]上午2:30 util/async_.py (ERROR)
Invalid connection from (client @=127.0.0.1:51688) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=127.0.0.1:51678) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=127.0.0.1:51671) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=127.0.0.1:51664) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]上午2:29 util/async_.py (ERROR)
Invalid connection from (client @=127.0.0.1:51659) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=127.0.0.1:51648) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=127.0.0.1:51635) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=127.0.0.1:51626) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]上午2:28 util/async_.py (ERROR)
Invalid connection from (client @=127.0.0.1:51620) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=127.0.0.1:51614) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=127.0.0.1:51607) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=192.168.31.1:49185) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=192.168.31.1:49176) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]上午2:27 util/async_.py (ERROR)
Invalid connection from (client @=192.168.31.1:49171) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=192.168.31.1:49161) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=218.91.245.173:41101) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=192.168.31.1:49156) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
Invalid connection from (client @=192.168.31.1:49147) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]上午2:26 util/async_.py (ERROR)
Invalid connection from (client @=192.168.31.1:49130) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
发表于 2019-9-16 16:18:53 | 显示全部楼层
希望作者能更新现在内置mqtt的使用方法
发表于 2019-9-17 19:27:17 | 显示全部楼层
之前我也遇到这个问题,你看下nodered 是不是勾了 mqtt3.1,把这个钩要去掉
发表于 2024-7-13 18:24:10 | 显示全部楼层
谢谢提醒!!!
GMT+8, 2026-1-14 06:19 , Processed in 0.472777 second(s), 12 queries , MemCached On.
