查看: 9987|回复: 9
[求助] 斐讯体脂秤S7插件 for HomeAssistant无法正常运行
发表于 2018-11-20 11:36:05 | 显示全部楼层 |阅读模式
从看到囧大的这个插件后,欣喜万分,好不容易能下载下来了,但是无法正常用,日志报错,希望囧大或者其他大神,能帮小弟看下,谢谢
我的是
0.82.0
版的,不知道有没有影响
2018-11-20 09:01:40 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/token to 172.30.32.2 (auth: False)
2018-11-20 09:01:40 INFO (MainThread) [homeassistant.components.http.view] Serving /api/ to 172.30.32.2 (auth: True)
2018-11-20 09:02:21 WARNING (MainThread) [homeassistant.components.sensor] Updating phicomm_balance sensor took longer than the scheduled update interval 0:03:20
2018-11-20 09:03:27 ERROR (SyncWorker_19) [custom_components.sensor.phicomm_balance] get token failed
2018-11-20 09:03:27 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 240, in async_update_ha_state
    device_attr = self.device_state_attributes
  File "/config/custom_components/sensor/phicomm_balance.py", line 97, in device_state_attributes
    'weight': self._detail['weight'],
KeyError: 'weight'
2018-11-20 09:05:42 INFO (SyncWorker_16) [custom_components.sensor.phicomm_balance] Updating the sensor...
2018-11-20 09:05:52 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.phicomm_balance is taking over 10 seconds
2018-11-20 09:06:40 INFO (MainThread) [homeassistant.components.http.view] Serving /api/ to 172.30.32.2 (auth: True)
2018-11-20 09:07:53 ERROR (SyncWorker_16) [custom_components.sensor.phicomm_balance] get token failed
2018-11-20 09:09:03 WARNING (MainThread) [homeassistant.components.sensor] Updating phicomm_balance sensor took longer than the scheduled update interval 0:03:20
2018-11-20 09:10:06 ERROR (SyncWorker_16) [custom_components.sensor.phicomm_balance] get token failed
2018-11-20 09:10:07 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
KeyError: 'weight'
2018-11-20 09:11:40 INFO (MainThread) [homeassistant.components.http.view] Serving /api/ to 172.30.32.2 (auth: True)
2018-11-20 09:12:23 INFO (SyncWorker_14) [custom_components.sensor.phicomm_balance] Updating the sensor...
2018-11-20 09:12:33 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.phicomm_balance is taking over 10 seconds
2018-11-20 09:14:32 ERROR (SyncWorker_14) [custom_components.sensor.phicomm_balance] get token failed
2018-11-20 09:15:44 WARNING (MainThread) [homeassistant.components.sensor] Updating phicomm_balance sensor took longer than the scheduled update interval 0:03:20
流水无味
灌水之王
发表于 2018-11-20 12:04:57 | 显示全部楼层
服务器都挂了  肯定不能用了啊  等大神做局域网离线版
但是这玩意估计玩的人不多
 楼主| 发表于 2018-11-20 12:20:16 | 显示全部楼层
但是这玩意估计玩的人不多  ...
感觉不是服务器的问题,看日志是程序有问题。我手机登陆,看数据都没问题
流水无味
灌水之王
发表于 2018-11-20 12:34:23 | 显示全部楼层
get token failed……
发表于 2018-11-20 14:32:09 | 显示全部楼层
这个我自己都好久没有用了,我也说不清原因了。
 楼主| 发表于 2018-11-20 15:02:01 | 显示全部楼层
挺好的一个东西,可惜了
发表于 2018-11-20 15:23:50 | 显示全部楼层
douzs 发表于 2018-11-20 15:02
挺好的一个东西,可惜了
这东西意义不大。。
cnbb 手机认证
发表于 2018-11-22 10:04:37 | 显示全部楼层
难怪。。我手上也有一台~~也是好不容易可以下载了,结果~~
发表于 2018-12-12 13:55:00 | 显示全部楼层
但是这玩意估计玩的人不多
发表于 2019-5-27 18:24:09 | 显示全部楼层
盼望我也能试试!!!
GMT+8, 2025-12-24 03:08 , Processed in 1.697673 second(s), 10 queries , MemCached On.
