楼主: 三木
[插件集成] 通过IPV6实现外网访问hass服务#阿里云DDNS插件&IPV6解析
发表于 2023-10-7 14:39:38 | 显示全部楼层
发表于 2023-10-7 14:47:12 | 显示全部楼层
试试看看
发表于 2023-10-7 15:13:50 | 显示全部楼层
学习资料收到了
发表于 2023-10-15 03:00:26 | 显示全部楼层
整啊后大大大大111111
发表于 2023-10-16 08:44:43 | 显示全部楼层
失败了,重启都报错,说是The system cannot restart because the configuration is not valid: Integration error: domain - Integration 'domain' not found. Integration error: sub_domain - Integration 'sub_domain' not found. Integration error: line - Integration 'line' not found. Integration error: scan_interval - Integration 'scan_interval' not found. Integration error: access_key_secret - Integration 'access_key_secret' not found. Platform error sensor.aliddns - Integration 'aliddns' not found. Integration error: type - Integration 'type' not found. Integration error: access_key_id - Integration 'access_key_id' not found.
发表于 2023-10-17 14:43:45 | 显示全部楼层
11111111111111
发表于 2023-10-18 06:34:43 | 显示全部楼层
终于找到V6的了
发表于 2023-10-18 08:12:53 | 显示全部楼层
谢谢楼主
发表于 2023-10-20 19:45:30 | 显示全部楼层
asd ad D a
发表于 2023-10-24 13:40:56 | 显示全部楼层
回去试一试
GMT+8, 2026-2-2 04:09 , Processed in 0.058687 second(s), 10 queries , MemCached On.
