楼主: 花开堪折枝
[流程系列] 【node-red】彩云天气
发表于 2021-3-1 21:30:43 | 显示全部楼层
学习MQTT
发表于 2021-3-2 15:42:18 | 显示全部楼层
发表于 2021-3-7 20:33:29 | 显示全部楼层
感谢分享!!!
发表于 2021-3-17 18:58:29 | 显示全部楼层
学习学习
发表于 2021-3-21 21:47:49 | 显示全部楼层
前来学习一下。 这个好像是有点厉害的
发表于 2021-3-23 15:46:49 | 显示全部楼层
新手学习
发表于 2021-3-24 10:46:56 | 显示全部楼层
我来看看,我能不能学会。
发表于 2021-3-26 23:20:30 | 显示全部楼层
按照大神配置的 配置文件报错呢。。。
Invalid config for [group]: [view] is an invalid option for [group]. Check: group->group->caiyunMinutely->view. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?). Invalid config for [sensor.mqtt]: [friendly_name] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->friendly_name. (See ?, line ?).
发表于 2021-4-5 20:57:53 | 显示全部楼层
谢谢分享
发表于 2021-4-9 21:38:44 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-3 15:03 , Processed in 0.083031 second(s), 16 queries , MemCached On.
