查看: 5178|回复: 3
[基础教程] 求教大神,安装homeassistant出现这个
发表于 2018-11-5 00:55:37 | 显示全部楼层 |阅读模式
(homeassistant) homeassistant@localhost:/home/ppwtz$ pip3 install -U homeassistant
Looking in indexes: http://mirrors.ustc.edu.cn/pypi/web/simple/
Collecting homeassistant
  The repository located at mirrors.ustc.edu.cn is not a trusted or secure host and is being ignored. If this repository is available via HTTPS we recommend you use HTTPS instead, otherwise you may silence this warning and allow it anyway with '--trusted-host mirrors.ustc.edu.cn'.
  Could not find a version that satisfies the requirement homeassistant (from versions: )
No matching distribution found for homeassistant
发表于 2018-11-5 09:22:01 | 显示全部楼层
把pip源的http 改成 https 试试
发表于 2018-11-5 10:06:14 | 显示全部楼层
推荐docker安装,不用折腾
 楼主| 发表于 2018-11-5 23:23:55 | 显示全部楼层
baymin 发表于 2018-11-5 10:06
推荐docker安装,不用折腾
怎么弄啊
GMT+8, 2026-1-2 16:53 , Processed in 0.410761 second(s), 12 queries , MemCached On.
