查看: 4074|回复: 3
[求助] 群晖添加空调伴侣问题
发表于 2018-11-2 23:05:09 | 显示全部楼层 |阅读模式
一直报错翻了半天论坛也没发现怎么解决
Error during setup of component xiaomi_aqara
  File "/usr/src/app/homeassistant/setup.py", line 148, in _async_setup_component
    component.setup, hass, processed_config)  # type: ignore
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/src/app/homeassistant/components/xiaomi_aqara.py", line 130, in setup
    xiaomi.discover_gateways()
  File "/usr/local/lib/python3.6/site-packages/xiaomi_gateway/__init__.py", line 66, in discover_gateways
    gateway.get('key'), self._interface, gateway.get('proto'))
  File "/usr/local/lib/python3.6/site-packages/xiaomi_gateway/__init__.py", line 209, in __init__
    if self._discover_devices():
  File "/usr/local/lib/python3.6/site-packages/xiaomi_gateway/__init__.py", line 216, in _discover_devices
    else self._send_cmd(cmd, "discovery_rsp")
  File "/usr/local/lib/python3.6/site-packages/xiaomi_gateway/__init__.py", line 309, in _send_cmd
    resp = json.loads(data.decode())
  File "/usr/local/lib/python3.6/json/__init__.py", line 354, in loads
    return _default_decoder.decode(s)
  File "/usr/local/lib/python3.6/json/decoder.py", line 339, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/local/lib/python3.6/json/decoder.py", line 355, in raw_decode
    obj, end = self.scan_once(s, idx)
json.decoder.JSONDecodeError: Expecting ',' delimiter: line 1 column 1025 (char 1024)
 楼主| 发表于 2018-11-3 09:58:47 | 显示全部楼层
你们群晖用着都没问题吗
 楼主| 发表于 2018-11-9 11:04:51 | 显示全部楼层
自行解决了    单个网关接入有上限     和网络环境应该也有关系
我的是单网关接入超过18个设备 HA就开始报错    低于18个没问题
必要的时候把这个文件夹  /config/.storage/    删掉重启      应该就可以解决了
发表于 2020-2-20 00:14:04 | 显示全部楼层
就没成功过 兼容性问题太多了
GMT+8, 2025-11-7 22:48 , Processed in 0.670955 second(s), 5 queries , MemCached On.
