查看: 5954|回复: 2
[求助] 摄像头接入 HK,图像不显示
发表于 2018-11-2 14:08:31 | 显示全部楼层 |阅读模式
摄像头接入 HK,但是无图像显示。我看 homebridge 日志里没有其他报错信息。接入 HA 是正常的
 楼主| 发表于 2018-11-2 14:12:44 | 显示全部楼层
        "bridge": {
                "name": "Homebridge",
                "username": "CC:22:3D:E3:CE:30",
                "port": 51826,
                "pin": "031-45-154"
        "description": "This is an example configuration file. You can use this as a template for creating your own configuration file containing devices you actually own.",
        "accessories": [],
        "platforms": [{
                        "platform": "yeelight",
                        "name": "yeelight"
                        "platform": "MiRobotVacuumPlatform",
                        "deviceCfgs": {
                                "type": "MiRobotVacuum",
                                "ip": "192.168.1.117",
                                "token": "xxxxxx",
                                "robotVacuumName": "robot vacuum",
                                "enablePauseToCharge": true,
                                "robotVacuumDisable": false
      "platform": "Camera-ffmpeg",
      "cameras": [
          "name": "My Camera",
          "videoConfig": {
            "source": "-re -i rtsp://admin:[email protected]/Streaming/Channels/1",
            "maxStreams": 2,
            "maxWidth": 1280,
            "maxHeight": 720,
            "maxFPS": 10
发表于 2018-11-2 16:41:50 | 显示全部楼层
我的是这样,正常用
GMT+8, 2025-12-25 10:12 , Processed in 0.634600 second(s), 9 queries , MemCached On.
