查看: 2533|回复: 2
[求助] 小米風扇自動化報錯
发表于 2018-11-1 21:49:29 | 显示全部楼层 |阅读模式
小米風扇自動化報錯, 求師兄指教, thanks!!
- alias: fan level 1
  initial_state: true
  hide_entity: true
  trigger:
    - platform: state
      entity_id: input_boolean.fan_level_1
      to: 'on'
  action:
    - service: fan.set_speed
      data_template:
        entity_id: fan.dining_room_fan
        speed: Level1
- alias: fan level 2
  initial_state: true
  hide_entity: true
  trigger:
    - platform: state
      entity_id: input_boolean.fan_level_2
      to: 'on'
  action:
      data_template:
        speed: Level2
- alias: fan level 3
  initial_state: true
  hide_entity: true
  trigger:
    - platform: state
      entity_id: input_boolean.fan_level_3
      to: 'on'
  action:
      data_template:
        speed: Level3
- alias: fan level 4
  initial_state: true
  hide_entity: true
  trigger:
    - platform: state
      entity_id: input_boolean.fan_level_4
      to: 'on'
  action:
      data_template:
        speed: Level4
2018-11-01 21:39:12 ERROR (SyncWorker_0) [homeassistant.util.yaml] while scanning for the next token
found character '\t' that cannot start any token
  in "/config/automations.yaml", line 1781, column 1
2018-11-01 21:39:12 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: while scanning for the next token
发表于 2018-11-2 11:49:15 | 显示全部楼层
把tab制表符换成空格。
 楼主| 发表于 2018-11-2 13:56:34 | 显示全部楼层
Jones 发表于 2018-11-2 11:49
把tab制表符换成空格。
thanks Jones!!
GMT+8, 2025-12-16 19:43 , Processed in 0.051759 second(s), 4 queries , MemCached On.
