查看: 8700|回复: 1
请问大神Hass.io Add-ons中MQTT和SSH怎么配置的
发表于 2018-10-31 00:21:40 | 显示全部楼层 |阅读模式
已在Hass.io Add-ons中已安装如下插件
现在无法正常启动,估计是秘钥和证书未配置,请大神帮忙看看是怎么生成的,下面是配置
1.MQTT Server & Web client
  "log_level": "info",
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem",
  "web": {
    "enabled": true,
    "username": "mqtt",
    "password": "123",
    "ssl": true
  "broker": {
    "enabled": true,
    "enable_ws": false,
    "enable_mqtt": false,
    "enable_ws_ssl": true,
    "enable_mqtt_ssl": true,
    "allow_anonymous": false
  "mqttusers": [
      "username": "mqtt",
      "password": "123",
      "readonly": true,
      "topics": [
2.SSH & Web Terminal
  "ssh": {
    "enable": true,
    "port": 22,
    "username": "hassio",
    "password": "123",
    "authorized_keys": [],
    "sftp": false,
    "compatibility_mode": false,
    "allow_agent_forwarding": false,
    "allow_remote_port_forwarding": false,
    "allow_tcp_forwarding": false
  "web": {
    "enable": true,
    "port": 7681,
    "password": "123",
    "ssl": true,
  "share_sessions": true,
  "packages": [],
  "init_commands": []
aaa
34
发表于 2018-12-14 19:52:23 | 显示全部楼层
问题解决了吗
GMT+8, 2025-12-23 13:48 , Processed in 0.218178 second(s), 7 queries , MemCached On.
