查看: 6093|回复: 3
[求助] 想写一个Airx C1pm25检测仪接入ha,搞不定
发表于 2018-10-24 01:27:41 | 显示全部楼层 |阅读模式
尝试在此贴基础上修改,搞不定
https://bbs.hassbian.com/forum.p ... ght=airx&page=1
json格式都是一样的,只是少了speed,滤芯剩余,开关,这几个值,我尝试把这些删掉,不行,总是报错,coding太难了
获取到pm25 pm10 pm1数据就行
 楼主| 发表于 2018-10-24 01:57:13 | 显示全部楼层
uh 就在刚才 我发现我成功了。。。发个帖子吧
参与人数 2金钱 +9 收起 理由
windgo + 4 厉害了word楼主!
neroxps + 5
发表于 2018-10-24 13:15:01 | 显示全部楼层
C1只取值不控制就很方便了,直接用Command line就可以做一个package,省去写插件.
之前用rest也可以,但现在好像不行了.
  #C1传感器
  - platform: command_line
    command: "curl -d 'userId=自己的userid&token=自己的token&device_id=c1设备值&' 'http://luxcar.com.cn/airx/airx_iot_reportup/web/equipment/loadDeviceData'"
    value_template: '{{ value_json["data"]["pm25"] }}'
    unit_of_measurement: 'μg/m3'
    # 更新时间 /秒
    scan_interval: 60
    json_attributes:
      - data
      - success
  - platform: template
    sensors:
      c1_pm1:
        friendly_name: "PM1"
        value_template: "{{ states.sensor.c1_pm25.attributes.data.pm1 }}"
      c1_pm10:
        friendly_name: "PM10"
        value_template: "{{ states.sensor.c1_pm25.attributes.data.pm10 }}"
      c1_pm25_city:
        friendly_name: "城市PM2.5"
        value_template: "{{ states.sensor.c1_pm25.attributes.data.pm25_city }}"
homeassistant:
# Customze-UI 颜色随值变化,没装可以删掉
  customize_glob:
    sensor.c1_pm*:
     icon: mdi:blur
     templates:
      hs_color: if (state <= 50 ) return [120, 75.6, 80.4]; if (state > 50 && state <= 100 ) return [51, 100.0, 100.0]; else return [0, 100.0, 100.0];
# 普通命名
  customize:
    sensor.c1_pm25 :
      friendly_name: PM2.5
      icon: mdi:blur
    sensor.c1_pm1 :
      icon: mdi:blur
    sensor.c1_pm10 :
      icon: mdi:blur
    sensor.c1_pm25_city :
      icon: mdi:blur
group:
  airx_c1:
    view: no
    control: hidden
    entities:
      - sensor.c1_pm25
      - sensor.c1_pm1
      - sensor.c1_pm10
      - sensor.c1_pm25_city
airx_c1.zip
981 Bytes, 下载次数: 2
 楼主| 发表于 2018-10-24 13:26:04 | 显示全部楼层
之前用rest也可以,但现在好 ...
谢谢 我觉得这样比写插件好 过会儿下载
GMT+8, 2025-12-24 19:27 , Processed in 1.429159 second(s), 10 queries , MemCached On.
