查看: 9522|回复: 2
[基础教程] MQTT安装 请教
发表于 2018-10-23 09:33:03 | 显示全部楼层 |阅读模式
各位大神小弟按照
https://bbs.hassbian.com/thread-4520-1-1.html
这位大神的自动脚本安装了 homeassistant
在hassio里安装了mqtt
在start mqtt后web页面一刷新这个start按钮就有出来了,小弟无法判断是mqtt是安装失败了还是页面就是这样形态。希望给予支持,谢谢
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: MQTT Server & Web client v0.1.1
Mosquitto MQTT Server bundled with Hivemq's web client
By: Franck Nijhof <[email protected]>
amd64 / Ubuntu 18.04.1 LTS / HA 0.80.2 / SU 138 / stable
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 10-requirements.sh: executing...
curl: (6) Could not resolve host: api.pwnedpasswords.com
ERROR: Something went wrong contacting the HIBP API
WARNING: Could not check password, assuming it is safe.
FATAL: The configured certfile is not found
[cont-init.d] 10-requirements.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
发表于 2018-10-30 23:32:55 | 显示全部楼层
解决了么?
 楼主| 发表于 2019-2-13 14:43:57 | 显示全部楼层
果断放弃了 哈哈
GMT+8, 2026-1-2 04:26 , Processed in 0.138829 second(s), 14 queries , MemCached On.
