查看: 3624|回复: 2
N1安装HASS获取DC1数据显示未知
发表于 2018-10-16 10:13:11 | 显示全部楼层 |阅读模式
按照安装了N1,HASS可以正常启动,配置后主页2个显示未知,求助大佬,该怎么搞?
IP劫持已经做了,PING是正常到N1的.DC1的地址也是正确的地址.
HASS安装这位大佬的:https://bbs.hassbian.com/thread-4520-1-1.html
修改部分:只是在/usr/share/hassio/homeassistant/configuration.yaml 内添加了
homeassistant:
配置文件2个正常放在packages和custom_components/switch内,重启后系统提示下图的未知数据,
系统日志:
ress the button to load the full Home Assistant log.
2018-10-16 01:33:53 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrievedTraceback (most recent call last):  File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 56, in async_setup_component    return await task  # type: ignore  File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 118, in _async_setup_component    conf_util.async_process_component_config(hass, config, domain)  File "/usr/local/lib/python3.6/site-packages/homeassistant/config.py", line 757, in async_process_component_config    platform = get_platform(hass, domain, p_name)  File "/usr/local/lib/python3.6/site-packages/homeassistant/loader.py", line 62, in get_platform    return get_component(hass, PLATFORM_FORMAT.format(domain, platform))  File "/usr/local/lib/python3.6/site-packages/homeassistant/loader.py", line 94, in get_component    module = importlib.import_module(path)  File "/usr/local/lib/python3.6/importlib/__init__.py", line 126, in import_module    return _bootstrap._gcd_import(name[level:], package, level)  File "<frozen importlib._bootstrap>", line 994, in _gcd_import  File "<frozen importlib._bootstrap>", line 971, in _find_and_load  File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 665, in _load_unlocked  File "<frozen importlib._bootstrap_external>", line 674, in exec_module  File "<frozen importlib._bootstrap_external>", line 781, in get_code  File "<frozen importlib._bootstrap_external>", line 741, in source_to_code  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed  File "/config/custom_components/switch/phicomm_dc1m.py", line 7    <!DOCTYPE html>    ^SyntaxError: invalid syntax2018-10-16 01:33:53 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 当前功率, the state is unknown.2018-10-16 01:33:53 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 当前电压, the state is unknown.2018-10-16 01:33:53 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 当前电压, the state is unknown.2018-10-16 01:33:53 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 当前功率, the state is unknown.2018-10-16 01:34:03 WARNING (SyncWorker_10) [netdisco.ssdp] Error fetching description at http://[fd72:cfd1:4f4a::1]:5000/rootDesc.xml2018-10-16 01:34:28 ERROR (MainThread) [aiohttp.server] Error handling requestTraceback (most recent call last):  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 390, in start    resp = await self._request_handler(request)  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_app.py", line 366, in _handle    resp = await handler(request)  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_middlewares.py", line 106, in impl    return await handler(request)  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/static.py", line 66, in staticresource_middleware    return await handler(request)  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/real_ip.py", line 34, in real_ip_middleware    return await handler(request)  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/ban.py", line 67, in ban_middleware    return await handler(request)  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/auth.py", line 68, in auth_middleware    return await handler(request)  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/real_ip.py", line 34, in real_ip_middleware    return await handler(request)  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/ban.py", line 67, in ban_middleware    return await handler(request)  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/auth.py", line 68, in auth_middleware    return await handler(request)  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/view.py", line 113, in handle    result = await result  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/config/core.py", line 24, in post    errors = yield from async_check_ha_config_file(request.app['hass'])  File "/usr/local/lib/python3.6/site-packages/homeassistant/config.py", line 793, in async_check_ha_config_file    check_ha_config_file, hass)  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run    result = self.fn(*self.args, **self.kwargs)  File "/usr/local/lib/python3.6/site-packages/homeassistant/scripts/check_config.py", line 372, in check_ha_config_file    platform = loader.get_platform(hass, domain, p_name)  File "/usr/local/lib/python3.6/site-packages/homeassistant/loader.py", line 62, in get_platform    return get_component(hass, PLATFORM_FORMAT.format(domain, platform))  File "/usr/local/lib/python3.6/site-packages/homeassistant/loader.py", line 94, in get_component    module = importlib.import_module(path)  File "/usr/local/lib/python3.6/importlib/__init__.py", line 126, in import_module    return _bootstrap._gcd_import(name[level:], package, level)  File "<frozen importlib._bootstrap>", line 994, in _gcd_import  File "<frozen importlib._bootstrap>", line 971, in _find_and_load  File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 665, in _load_unlocked  File "<frozen importlib._bootstrap_external>", line 674, in exec_module  File "<frozen importlib._bootstrap_external>", line 781, in get_code  File "<frozen importlib._bootstrap_external>", line 741, in source_to_code  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed  File "/config/custom_components/switch/phicomm_dc1m.py", line 7    <!DOCTYPE html>    ^SyntaxError: invalid syntax
configuration和2个配置.zip
24.04 KB, 下载次数: 13
发表于 2018-10-16 15:56:38 | 显示全部楼层
猜测是版本问题,升级最新版homeassistant试试
发表于 2018-10-16 17:58:05 | 显示全部楼层
打开看看应该是下错了,重新下载
GMT+8, 2026-1-2 18:59 , Processed in 0.052427 second(s), 14 queries , MemCached On.
