查看: 9825|回复: 9
有大神研究R1 音箱 的吗?可以ADB了,发点日志
发表于 2018-10-15 15:14:10 | 显示全部楼层 |阅读模式
希望有安卓大神能定制固件,哈。发现自带airplay的,现在是要打开蓝牙才行。
进程:
root      201   1     6172   152   ffffffff 00000000 S /system/bin/rild
install   202   1     1176   164   ffffffff 00000000 S /system/bin/installd
keystore  204   1     4324   244   ffffffff 00000000 S /system/bin/keystore
root      209   1     815560 9456  ffffffff 00000000 S zygote
system    210   1     55008  464   ffffffff 00000000 S /system/bin/mediaserver
media_rw  211   1     3576   60    ffffffff 00000000 S /system/bin/sdcard
system    528   209   915228 31644 ffffffff 00000000 S system_server
u0_a1     664   209   564844 10476 ffffffff 00000000 S android.process.media
root      686   2     0      0     ffffffff 00000000 S kworker/1:2
wifi      691   1     4436   592   ffffffff 00000000 S /system/bin/wpa_supplicant
u0_a9     699   209   603592 24572 ffffffff 00000000 S com.wukongtv.wkhelper
u0_a10    759   209   901928 48440 ffffffff 00000000 S com.estrongs.android.pop
system    778   209   563952 8608  ffffffff 00000000 S com.phicomm.speaker.productiontest
system    799   209   568772 12576 ffffffff 00000000 S com.phicomm.speaker.bugreport
system    818   209   581580 15804 ffffffff 00000000 S com.phicomm.speaker.otaservice
system    838   209   577592 11148 ffffffff 00000000 S com.phicomm.speaker.systemtool
system    858   209   570236 10208 ffffffff 00000000 S com.phicomm.speaker.player
u0_a6     876   209   564620 11108 ffffffff 00000000 S com.phicomm.speaker.launcher
bluetooth 913   209   596696 9780  ffffffff 00000000 S com.android.bluetooth
dhcp      977   1     1108   232   ffffffff 00000000 S /system/bin/dhcpcd
radio     1020  209   563296 10396 ffffffff 00000000 S com.android.phone
u0_a10    1088  209   851040 32280 ffffffff 00000000 S com.estrongs.android.pop:local
root      1107  2     0      0     ffffffff 00000000 S kworker/0:2
u0_a8     1135  209   964764 99116 ffffffff 00000000 S com.phicomm.speaker.device
u0_a10    1168  759   3004   164   ffffffff 00000000 S /data/data/com.estrongs.android.pop/files/libestool2.so
system    1256  209   573764 11568 ffffffff 00000000 S com.phicomm.speaker.netctl
system    1281  209   569180 8472  ffffffff 00000000 S com.phicomm.speaker.player:NetPlayer
system    1326  209   566192 11936 ffffffff 00000000 S com.phicomm.speaker.airskill
system    1364  209   570236 8700  ffffffff 00000000 S com.phicomm.speaker.player:DlnaPlayer
system    1387  209   563808 9856  ffffffff 00000000 S com.phicomm.speaker.exceptionreporter
u0_a10    1412  209   854308 37964 ffffffff 00000000 S .esfm
u0_a11    1441  209   893928 29428 ffffffff 00000000 S com.hpplay.happyplay.aw
system    1463  209   568348 8452  ffffffff 00000000 S com.phicomm.speaker.player:AirPlayer
u0_a0     1492  209   563812 9952  ffffffff 00000000 S com.android.defcontainer
system    1685  209   567684 11132 ffffffff 00000000 S com.phicomm.speaker.systemtool:remote
u0_a11    1739  209   836576 21140 ffffffff 00000000 S com.hpplay.happyplay.aw:service1
u0_a11    1767  209   837632 20524 ffffffff 00000000 S com.hpplay.happyplay.aw:service2
root      15321 2     0      0     ffffffff 00000000 S kworker/u8:0
root      15730 2     0      0     ffffffff 00000000 S kworker/u8:2
shell     16183 1     7720   224   ffffffff 00000000 S /sbin/adbd
root      16205 2     0      0     ffffffff 00000000 S kworker/2:0
root      16206 2     0      0     ffffffff 00000000 S kworker/0:0
root      16207 2     0      0     ffffffff 00000000 S kworker/3:0
root      16238 2     0      0     ffffffff 00000000 S kworker/u9:0
root      16348 2     0      0     ffffffff 00000000 S kworker/u9:2
root      16394 2     0      0     ffffffff 00000000 S kworker/u9:1
root      16402 2     0      0     ffffffff 00000000 S kworker/2:2
root      16403 2     0      0     ffffffff 00000000 S kworker/0:1
root      16443 2     0      0     ffffffff 00000000 S kworker/3:2
root      16444 2     0      0     ffffffff 00000000 S kworker/1:0
shell     16454 16183 2424   708   00000000 b6eeba14 R ps
小讯音箱日志.txt.zip
54.33 KB, 下载次数: 10
发表于 2018-10-15 22:10:42 来自手机 | 显示全部楼层
楼主加油,终于看到希望了!
发表于 2018-10-24 14:00:08 | 显示全部楼层
想问下是怎么adb进去的?
 楼主| 发表于 2018-10-24 15:05:43 | 显示全部楼层
好像,只有首发办法才可以,之后的我不不清楚。tcp 连接的
发表于 2018-10-24 17:53:25 | 显示全部楼层
想问下R1的adb怎么开的呢
 楼主| 发表于 2018-10-24 19:18:36 | 显示全部楼层
http://www.right.com.cn/forum/thread-314666-1-1.html 后面斐讯应该已经封了,我的只有一台打开了adb
 楼主| 发表于 2018-10-24 19:26:03 | 显示全部楼层
本来想拆机,焊接usb的,可惜没那个技术
发表于 2018-10-27 23:51:35 | 显示全部楼层
USB我倒是焊上了。不过接电脑没有任何反应。
 楼主| 发表于 2018-10-28 09:36:26 | 显示全部楼层
可以查下那个ttl接口,我不懂电路
发表于 2018-11-28 15:10:19 | 显示全部楼层
默认还没打开adb?
GMT+8, 2026-1-2 12:40 , Processed in 0.199486 second(s), 16 queries , MemCached On.
