查看: 4849|回复: 3
[技术探讨] 无权限怎么解决
发表于 2018-10-14 09:00:55 | 显示全部楼层 |阅读模式
● homebridge.service - Node.js HomeKit Server
   Loaded: loaded (/etc/systemd/system/homebridge.service; enabled; vendor preset: enabled)
   Active: active (running) since Sat 2018-10-13 18:41:58 +08; 13h ago
Main PID: 484 (homebridge)
   CGroup: /system.slice/homebridge.service
           └─484 homebridge
Oct 14 08:37:34 hassbian homebridge[484]: [10/14/2018, 12:37:34 AM] [HomeAssistant] Fetching HomeAssistant devices.
Oct 14 08:37:34 hassbian homebridge[484]: [10/14/2018, 12:37:34 AM] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
Oct 14 08:37:39 hassbian homebridge[484]: [10/14/2018, 12:37:39 AM] [HomeAssistant] Fetching HomeAssistant devices.
Oct 14 08:37:39 hassbian homebridge[484]: [10/14/2018, 12:37:39 AM] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
Oct 14 08:37:44 hassbian homebridge[484]: [10/14/2018, 12:37:44 AM] [HomeAssistant] Fetching HomeAssistant devices.
Oct 14 08:37:44 hassbian homebridge[484]: [10/14/2018, 12:37:44 AM] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
Oct 14 08:37:49 hassbian homebridge[484]: [10/14/2018, 12:37:49 AM] [HomeAssistant] Fetching HomeAssistant devices.
Oct 14 08:37:49 hassbian homebridge[484]: [10/14/2018, 12:37:49 AM] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
Oct 14 08:37:54 hassbian homebridge[484]: [10/14/2018, 12:37:54 AM] [HomeAssistant] Fetching HomeAssistant devices.
Oct 14 08:37:54 hassbian homebridge[484]: [10/14/2018, 12:37:54 AM] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
发表于 2018-10-14 09:40:23 | 显示全部楼层
文件的用户组和启动命令的用户组一致吗??
 楼主| 发表于 2018-10-14 14:35:25 | 显示全部楼层
怎么看?
 楼主| 发表于 2018-10-15 07:20:36 来自手机 | 显示全部楼层
大神帮帮忙
GMT+8, 2026-1-2 23:03 , Processed in 1.369814 second(s), 7 queries , MemCached On.
