查看: 9127|回复: 1
[技术探讨] 出现这个问题怎么解决?
发表于 2018-10-14 08:04:13 | 显示全部楼层 |阅读模式
Please set default_visibility in config.json to "hidden" or "visible"报错应该怎么处理?
 楼主| 发表于 2018-10-14 08:42:28 | 显示全部楼层
在config.json内增加如下字段,default_visibilityvisible{
    "bridge": {
        "default_visibility": "visible",
        "name": "Homebridge",
        "username": "B8:27:EB:10:61:E5",
        "port": 51826,
        "pin": "123-45-678"
    "platforms": [
    "platform": "HomeAssistant",
    "name": "HomeAssistant",
    "host": "http://192.168.2.112:8123",
   ////////////////////////      "default_visibility": "visible",          ///////////////////////////只复制这一段即可 去掉 / 记得把逗号也复制上
    "password": "yourapipassword",
    "supported_types": ["fan", "garage_door", "input_boolean", "light", "lock",$
GMT+8, 2026-1-2 23:02 , Processed in 0.217221 second(s), 6 queries , MemCached On.
