查看: 14771|回复: 14
请问0.79.3 HASS如何配置HOMEKIT
发表于 2018-10-12 22:43:14 | 显示全部楼层 |阅读模式
HomeAssistant 0.79.3 出现了
HOMEKIT(如图)错误,
没有连接码 请问需要怎么设置。
已按照官方在配置文件下添加代码:
homekit: TIM图片20181012223431.png TIM图片20181012223416.png
发表于 2018-10-12 22:54:24 | 显示全部楼层
多半config配置错误,发上来看看
 楼主| 发表于 2018-10-13 11:04:24 来自手机 | 显示全部楼层
coolbug111 发表于 2018-10-12 22:54
多半config配置错误,发上来看看
config脚本检查没错误,就添加了开启homekite的指令。
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-10-13 13:44:29 | 显示全部楼层
你把homekit 配置单独拿到packages文件夹里去,然后把配置发上来看看~估计是缩进问题,或者某个参数写了但是没配置实体
发表于 2018-10-13 17:24:02 | 显示全部楼层
jyz_0501 发表于 2018-10-13 13:44
你把homekit 配置单独拿到packages文件夹里去,然后把配置发上来看看~估计是缩进问题,或者某个参数写了 ...
他的问题和我的很像,也许就是一样的问题,下面是我的配置,最简了。
发表于 2018-10-13 17:27:56 | 显示全部楼层
这个是我的日志文件,请帮我看看
2018-10-10 12:03:17 WARNING (MainThread) [homeassistant.loader] You are using a custom component for tunnel2local which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-10-10 12:03:17 WARNING (MainThread) [homeassistant.loader] You are using a custom component for tts.google which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-10-10 12:03:17 WARNING (MainThread) [homeassistant.loader] You are using a custom component for introduction_hachina which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-10-10 12:03:18 WARNING (MainThread) [homeassistant.loader] You are using a custom component for redpoint which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-10-10 12:03:19 ERROR (MainThread) [homeassistant.setup] Error during setup of component homekit
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/setup.py", line 145, in _async_setup_component
    hass, processed_config)
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/homekit/__init__.py", line 73, in async_setup
    await hass.async_add_job(homekit.setup)
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/homekit/__init__.py", line 202, in setup
    from .accessories import HomeBridge, HomeDriver
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/homekit/accessories.py", line 8, in <module>
    from pyhap.accessory_driver import AccessoryDriver
  File "/home/pi/.homeassistant/deps/lib/python3.5/site-packages/pyhap/accessory_driver.py", line 45, in <module>
    from pyhap.hap_server import HAPServer
  File "/home/pi/.homeassistant/deps/lib/python3.5/site-packages/pyhap/hap_server.py", line 19, in <module>
    from Crypto.Protocol.KDF import HKDF
ImportError: cannot import name 'HKDF'
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-10-13 17:39:20 | 显示全部楼层
ounce 发表于 2018-10-13 17:27
这个是我的日志文件,请帮我看看
[code]2018-10-10 12:03:17 WARNING (MainThr ...
看看你的配置文件
或者你参考 https://bbs.hassbian.com/thread-3589-1-1.html
发表于 2018-10-13 20:49:20 | 显示全部楼层
jyz_0501 发表于 2018-10-13 17:39
看看你的配置文件
谢谢你的回复。我的情况是刚将镜像文件恢复到SD卡,放入树莓派,启动,显示正常;但仅在配置文件中添加 homekit: 就会出现错误提示。镜像是0.77版,编辑配置文件用的是Sublime txt 。
发表于 2018-10-16 15:38:10 | 显示全部楼层
理论上
homekit:
就可以
 楼主| 发表于 2018-10-20 22:19:06 | 显示全部楼层
根据日志发现为HASS自带脚本python版本问题,自动安装失败。
非DOCKER(也就是按M教程直装)解决方法为:
进入虚拟环境后  手动安装
pip install HAP-python
重启服务搞定。
GMT+8, 2026-1-2 16:53 , Processed in 1.389384 second(s), 10 queries , MemCached On.
