查看: 8445|回复: 3
[求助] 小米净水器接入问题
发表于 2018-10-9 14:26:46 | 显示全部楼层 |阅读模式
HA版本0.77.3
群晖docker
sensors.yaml
- platform: mi_water_purifier
  host: 192.168.50.228
  token: d0704ed4f59b22076354c6a7e70e33ed
以下是报错截图
 楼主| 发表于 2018-10-9 14:38:55 | 显示全部楼层
发表于 2018-11-17 01:53:25 | 显示全部楼层
你的 Token 出错了,重新抓一次更新
发表于 2018-12-3 20:02:37 | 显示全部楼层
请问在这个群晖docker下ha终端机里用什么命令编辑并保存protocol.py这个文件
python-miio==0.4.3 construct==2.9.45
ha启动后找不到小米的净水器
Sun Dec 02 2018 16:10:20 GMT+0800 (CST)
Error while setting up platform mi_water_purifier
  File "/config/custom_components/sensor/mi_water_purifier.py", line 159, in parse_data
    status = self._device.send('get_prop', [])
  File "/usr/local/lib/python3.6/site-packages/miio/device.py", line 263, in send
    self.__id = m.data.value["id"]
TypeError: 'NoneType' object is not subscriptable
  File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
    return fut.result()
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/config/custom_components/sensor/mi_water_purifier.py", line 34, in setup_platform
    waterPurifier = XiaomiWaterPurifier(device, name)
  File "/config/custom_components/sensor/mi_water_purifier.py", line 116, in __init__
    self.parse_data()
  File "/config/custom_components/sensor/mi_water_purifier.py", line 177, in parse_data
    except DeviceException:
NameError: name 'DeviceException' is not defined
unable to parse json '{"result":[net],"id":1}': Expecting value: line 1 column 12 (char 11)
GMT+8, 2025-12-16 01:46 , Processed in 0.785470 second(s), 7 queries , MemCached On.
