查看: 2578|回复: 3
Docker安装hass.io弹不出web界面,怎么办
发表于 2018-10-9 10:16:27 | 显示全部楼层 |阅读模式
昨天晚上通过docker安装hass.io.无法使用web界面。web一直停留正在加载当中,log我没看见有错误,求大神指点
-- Logs begin at Thu 2016-11-03 17:16:43 UTC. --
Oct 09 02:06:37 raspberrypi hassio-supervisor[1255]: 18-10-09 02:06:37 INFO (Syn                                                  cWorker_1) [hassio.docker.interface] Attach to image homeassistant/raspberrypi3-                                                  homeassistant with version 0.79.3
Oct 09 02:06:37 raspberrypi hassio-supervisor[1255]: 18-10-09 02:06:37 INFO (Mai                                                  nThread) [hassio.addons.git] Load add-on /data/addons/core repository
Oct 09 02:06:37 raspberrypi hassio-supervisor[1255]: 18-10-09 02:06:37 INFO (Mai                                                  nThread) [hassio.addons.git] Load add-on /data/addons/git/a0d7b954 repository
Oct 09 02:06:37 raspberrypi hassio-supervisor[1255]: 18-10-09 02:06:37 INFO (Mai                                                  nThread) [hassio.addons] Load add-ons: 46 all - 46 new - 0 remove
Oct 09 02:06:37 raspberrypi hassio-supervisor[1255]: 18-10-09 02:06:37 INFO (Mai                                                  nThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio                                                  -version/stable.json
Oct 09 02:06:39 raspberrypi hassio-supervisor[1255]: 18-10-09 02:06:39 INFO (Mai                                                  nThread) [hassio.snapshots] Found 0 snapshot files
Oct 09 02:06:39 raspberrypi hassio-supervisor[1255]: 18-10-09 02:06:39 INFO (Mai                                                  nThread) [__main__] Run Hass.io
Oct 09 02:06:39 raspberrypi hassio-supervisor[1255]: 18-10-09 02:06:39 INFO (Mai                                                  nThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
Oct 09 02:06:39 raspberrypi hassio-supervisor[1255]: 18-10-09 02:06:39 INFO (Mai                                                  nThread) [hassio.supervisor] Update Supervisor to version 134
Oct 09 02:06:39 raspberrypi hassio-supervisor[1255]: 18-10-09 02:06:39 INFO (Syn                                                  cWorker_2) [hassio.docker.interface] Pull image homeassistant/armhf-hassio-super                                                  visor tag 134.
Oct 09 02:07:35 raspberrypi hassio-supervisor[1255]: 18-10-09 02:07:35 INFO (SyncWorker_2) [hassio.docker.interface]              Tag image sha256:0f96c37681e0461d65baebfd160ee76e158e030ef70ea5c77405ba7d415c96c9 with version 134 as latest
Oct 09 02:07:35 raspberrypi hassio-supervisor[1255]: 18-10-09 02:07:35 INFO (MainThread) [hassio.supervisor] Fetch Ap             pArmor profile https://s3.amazonaws.com/hassio-version/apparmor.txt
Oct 09 02:07:39 raspberrypi hassio-supervisor[1255]: 18-10-09 02:07:39 INFO (MainThread) [hassio.host.apparmor] Add o             r Update AppArmor profile: hassio-supervisor
Oct 09 02:07:40 raspberrypi hassio-supervisor[1255]: 18-10-09 02:07:40 INFO (MainThread) [__main__] Stopping Hass.io
Oct 09 02:07:40 raspberrypi hassio-supervisor[1255]: 18-10-09 02:07:40 INFO (MainThread) [hassio.misc.dns] Stop DNS f             orwarding
Oct 09 02:07:40 raspberrypi hassio-supervisor[1255]: 18-10-09 02:07:40 INFO (MainThread) [hassio.core] Hass.io is dow             n
Oct 09 02:07:40 raspberrypi hassio-supervisor[1255]: 18-10-09 02:07:40 INFO (MainThread) [__main__] Close Hass.io
Oct 09 02:07:41 raspberrypi docker[1942]: hassio_supervisor
Oct 09 02:07:46 raspberrypi systemd[1]: hassio-supervisor.service: Service hold-off time over, scheduling restart.
Oct 09 02:07:46 raspberrypi systemd[1]: Stopped Hass.io supervisor.
Oct 09 02:07:46 raspberrypi systemd[1]: Starting Hass.io supervisor...
Oct 09 02:07:47 raspberrypi docker[1971]: hassio_supervisor
Oct 09 02:07:47 raspberrypi systemd[1]: Started Hass.io supervisor.
Oct 09 02:07:48 raspberrypi hassio-supervisor[1981]: hassio_supervisor
Oct 09 02:07:53 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:53 INFO (MainThread) [__main__] Initialize Hass.i             o setup
Oct 09 02:07:53 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:53 INFO (MainThread) [__main__] Setup HassIO
Oct 09 02:07:53 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:53 INFO (SyncWorker_0) [hassio.docker.supervisor]              Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 134
Oct 09 02:07:54 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:54 INFO (SyncWorker_1) [hassio.docker.interface]              Cleanup Docker images: ['homeassistant/armhf-hassio-supervisor:133']
Oct 09 02:07:55 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:55 INFO (MainThread) [hassio.utils.gdbus] Introsp             ect org.freedesktop.systemd1 on /org/freedesktop/systemd1
Oct 09 02:07:55 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:55 INFO (MainThread) [hassio.utils.gdbus] Connect              to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
Oct 09 02:07:55 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:55 INFO (MainThread) [hassio.utils.gdbus] Introsp             ect org.freedesktop.hostname1 on /org/freedesktop/hostname1
Oct 09 02:07:56 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:56 INFO (MainThread) [hassio.utils.gdbus] Connect              to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
Oct 09 02:07:56 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:56 INFO (MainThread) [hassio.utils.gdbus] Introsp             ect de.pengutronix.rauc on /
Oct 09 02:07:56 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:56 ERROR (MainThread) [hassio.utils.gdbus] DBus r             eturn error: b'Error: GDBus.Errorrg.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not pro             vided by any .service files\n'
Oct 09 02:07:56 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:56 WARNING (MainThread) [hassio.dbus.rauc] Can't              connect to rauc
Oct 09 02:07:56 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:56 INFO (MainThread) [hassio.host.info] Update lo             cal host information
Oct 09 02:07:56 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:56 INFO (MainThread) [hassio.utils.gdbus] Call or             g.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
Oct 09 02:07:56 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:56 INFO (MainThread) [hassio.host.services] Updat             e service information
Oct 09 02:07:56 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:56 INFO (MainThread) [hassio.utils.gdbus] Call or             g.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
Oct 09 02:07:56 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:56 INFO (MainThread) [hassio.host.apparmor] Load              AppArmor Profiles: {'hassio-supervisor'}
Oct 09 02:07:56 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:56 INFO (MainThread) [hassio.host.apparmor] AppAr             mor is not enabled on host
Oct 09 02:07:56 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:56 INFO (SyncWorker_0) [hassio.docker.interface]              Attach to image homeassistant/raspberrypi3-homeassistant with version 0.79.3
Oct 09 02:07:56 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:56 INFO (MainThread) [hassio.addons.git] Load add             -on /data/addons/git/a0d7b954 repository
Oct 09 02:07:56 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:56 INFO (MainThread) [hassio.addons.git] Load add             -on /data/addons/core repository
Oct 09 02:07:57 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:57 INFO (MainThread) [hassio.addons] Load add-ons             : 46 all - 46 new - 0 remove
Oct 09 02:07:57 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:57 INFO (MainThread) [hassio.updater] Fetch updat             e data from https://s3.amazonaws.com/hassio-version/stable.json
Oct 09 02:07:58 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:58 INFO (MainThread) [hassio.snapshots] Found 0 s             napshot files
Oct 09 02:07:58 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:58 INFO (MainThread) [__main__] Run Hass.io
Oct 09 02:07:58 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:58 INFO (MainThread) [hassio.misc.dns] Start DNS              port forwarding for host add-ons
Oct 09 02:07:58 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:58 INFO (MainThread) [hassio.core] Ignore Hass.io              auto updates on dev channel
Oct 09 02:07:58 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:58 INFO (MainThread) [hassio.api] Start API on 17             2.30.32.2
Oct 09 02:07:58 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:58 INFO (MainThread) [hassio.addons] Startup init             ialize run 0 add-ons
Oct 09 02:07:58 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:58 INFO (MainThread) [hassio.addons] Startup syst             em run 0 add-ons
Oct 09 02:07:58 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:58 INFO (MainThread) [hassio.addons] Startup serv             ices run 0 add-ons
Oct 09 02:07:58 raspberrypi hassio-supervisor[1981]: 18-10-09 02:07:58 INFO (SyncWorker_3) [hassio.docker.interface]              Clean homeassistant/raspberrypi3-homeassistant Docker application
Oct 09 02:08:00 raspberrypi hassio-supervisor[1981]: 18-10-09 02:08:00 INFO (SyncWorker_3) [hassio.docker.homeassista             nt] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.79.3
Oct 09 02:08:30 raspberrypi hassio-supervisor[1981]: 18-10-09 02:08:30 INFO (MainThread) [hassio.homeassistant] Detec             t a running Home Assistant instance
Oct 09 02:08:30 raspberrypi hassio-supervisor[1981]: 18-10-09 02:08:30 INFO (MainThread) [hassio.addons] Startup appl             ication run 0 add-ons
Oct 09 02:08:30 raspberrypi hassio-supervisor[1981]: 18-10-09 02:08:30 INFO (MainThread) [hassio.tasks] All core task             s are scheduled
Oct 09 02:08:30 raspberrypi hassio-supervisor[1981]: 18-10-09 02:08:30 INFO (MainThread) [hassio.core] Hass.io is up              and running
 楼主| 发表于 2018-10-9 21:05:55 | 显示全部楼层
没人知道吗?
 楼主| 发表于 2018-10-10 10:11:15 | 显示全部楼层
好尴尬
发表于 2018-10-11 08:43:23 | 显示全部楼层
装个portainer自己看看HA有没有启用
然后在确认一下最后的安装命令有没有执行成功
GMT+8, 2026-1-2 22:54 , Processed in 0.052446 second(s), 13 queries , MemCached On.
