查看: 6108|回复: 5
[求助] tts蓝牙音箱无法开启
发表于 2018-10-8 15:48:08 | 显示全部楼层 |阅读模式
You are using a custom component for device_tracker.bluetooth_tracker which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant
You are using a custom component for media_player.tts_bluetooth_speaker which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
Not initializing device_tracker.bluetooth_tracker because could not install requirement pybluez==0.22
Unable to prepare setup for platform device_tracker.bluetooth_tracker: Could not install all requirements.
一连接就报这个错误但是pybluez==0.22环境我是已经安装好的
有没有大佬知道怎么解决的啊,求教
发表于 2018-10-9 09:00:56 | 显示全部楼层
放弃吧,蓝牙TTS 成功率好低, 我昨天 折腾一天, 结果在 命令行 可以听到 声音, HA 里怎么搞都没有,,,,
 楼主| 发表于 2018-10-9 11:24:56 | 显示全部楼层
sunwon 发表于 2018-10-9 09:00
放弃吧,蓝牙TTS 成功率好低, 我昨天 折腾一天, 结果在 命令行 可以听到 声音, HA 里怎么搞都没有,,, ...
我命令行都出不来现在,巨难受
发表于 2018-10-9 11:44:54 | 显示全部楼层
命令行,要手工启动服务, 然后手工 配对,链接,   就会听到
 楼主| 发表于 2018-10-9 13:33:25 | 显示全部楼层
直接连进ubuntu可以听到,然后命令行就一直连不上了
发表于 2018-10-20 14:34:12 | 显示全部楼层
我命令行都出不来现在,巨难受
GMT+8, 2025-12-24 19:27 , Processed in 1.248159 second(s), 10 queries , MemCached On.
