查看: 15749|回复: 21
新人請教小米網關問題
发表于 2018-10-7 03:58:54 | 显示全部楼层 |阅读模式
硬體條件樹莓派3b+
sandisk 128gb
遵照https://www.home-assistant.io/getting-started/
這個步驟安裝完hass.io
也順利的進到系統
但是當要把小米網關加進去時
總是加不了
官網看了又看
打了又打
甚至也整個重頭來過
紿終加不了
看了System log
也看不出所以然
18-10-06 20:03:13 INFO (MainThread) [__main__] Initialize Hass.io setup
18-10-06 20:03:13 INFO (MainThread) [__main__] Setup HassIO
18-10-06 20:03:13 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 133
18-10-06 20:03:13 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
18-10-06 20:03:14 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
18-10-06 20:03:14 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
18-10-06 20:03:14 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
18-10-06 20:03:14 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
18-10-06 20:03:14 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: de.pengutronix.rauc - /
18-10-06 20:03:14 INFO (MainThread) [hassio.host.info] Update local host information
18-10-06 20:03:14 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
18-10-06 20:03:14 INFO (MainThread) [hassio.host.services] Update service information
18-10-06 20:03:14 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
18-10-06 20:03:14 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
18-10-06 20:03:14 INFO (MainThread) [hassio.host.services] Reload local service hassos-apparmor.service
18-10-06 20:03:14 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
18-10-06 20:03:14 INFO (MainThread) [hassio.hassos] Detect HassOS 1.11 on host system
18-10-06 20:03:14 INFO (SyncWorker_1) [hassio.docker.hassos_cli] Found HassOS CLI homeassistant/armhf-hassio-cli with version 7
18-10-06 20:03:15 INFO (SyncWorker_0) [hassio.docker.interface] Attach to image homeassistant/raspberrypi3-homeassistant with version 0.79.3
18-10-06 20:03:15 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/core repository
18-10-06 20:03:15 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/git/a0d7b954 repository
18-10-06 20:03:15 INFO (MainThread) [hassio.addons] Load add-ons: 47 all - 47 new - 0 remove
18-10-06 20:03:15 INFO (SyncWorker_0) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-configurator with version 2
18-10-06 20:03:15 INFO (SyncWorker_3) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-ssh with version 4
18-10-06 20:03:15 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-samba with version 6
18-10-06 20:03:16 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
18-10-06 20:03:17 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
18-10-06 20:03:17 INFO (MainThread) [__main__] Run Hass.io
18-10-06 20:03:17 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
18-10-06 20:03:17 INFO (MainThread) [hassio.core] Ignore Hass.io auto updates on dev channel
18-10-06 20:03:17 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
18-10-06 20:03:17 INFO (MainThread) [hassio.addons] Startup initialize run 0 add-ons
18-10-06 20:03:17 INFO (MainThread) [hassio.addons] Startup system run 0 add-ons
18-10-06 20:03:17 INFO (MainThread) [hassio.addons] Startup services run 2 add-ons
18-10-06 20:03:18 INFO (SyncWorker_7) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-samba with version 6
18-10-06 20:03:47 INFO (SyncWorker_8) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-ssh with version 4
18-10-06 20:03:53 INFO (SyncWorker_6) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.79.3
18-10-06 20:04:54 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-10-06 20:04:54 INFO (MainThread) [hassio.addons] Startup application run 1 add-ons
18-10-06 20:04:57 INFO (SyncWorker_12) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-configurator with version 2
18-10-06 20:05:02 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
18-10-06 20:05:02 INFO (MainThread) [hassio.core] Hass.io is up and running
18-10-06 20:05:05 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services/persistent_notification/create access from core_configurator
18-10-06 20:05:05 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
搞了兩天多..
以下圖片請參考
发表于 2018-10-7 08:44:43 | 显示全部楼层
经常出现这种毛病。
 楼主| 发表于 2018-10-8 06:03:29 | 显示全部楼层
今天試得結果
變成連不到網關..
這算有進展嗎?
還特地下載安卓模擬器確認密碼有沒有不一樣..
在網路上有搜到這篇
https://community.home-assistant ... y-v3-to-ha/65720/32
機乎跟我的一樣
現在在懷疑是不是跟他一樣的問題
在想要不要再買一個網關試試看..
发表于 2018-10-10 07:47:14 来自手机 | 显示全部楼层
你上面的LOG沒有跟網關有關的訊息
发表于 2018-10-10 07:49:17 来自手机 | 显示全部楼层
我不清楚HASS.IO加小米網關是否要做什麼設定,但我建議你把你有做的設定都寫出來好方便抓問題
czde
发表于 2018-10-10 15:13:19 | 显示全部楼层
用SocketTool.exe调试
设置UDP SERVERIP:224.0.0.50
端口:4321
发送内容:{"cmd":"whois"}
如果有返回则证明网关正常,没有返回请检查路由器是否把UDP包拦截了
 楼主| 发表于 2018-10-10 15:51:19 | 显示全部楼层
windgo 发表于 2018-10-10 07:49
我不清楚HASS.IO加小米網關是否要做什麼設定,但我建議你把你有做的設定都寫出來好方便抓問題 ...
若照頂樓的第六張官方教學圖片來說
只要照他的方式打上去即可
而我的為啥會比他多一些是因為一直爬文
一直看文章
東加西加測出來的結果
而且從頭到尾都只動'configuration.yaml'這個檔而已
 楼主| 发表于 2018-10-10 15:52:22 | 显示全部楼层
czde 发表于 2018-10-10 15:13
用SocketTool.exe调试
端口:4321
這個我會先照您的方法先測試看看網關是否正常
 楼主| 发表于 2018-10-10 22:24:32 | 显示全部楼层
用SocketTool.exe调试
端口:4321
抱歉
小白找到了此軟體
http://www.xdowns.com/soft/1/44/2014/Soft_125229.html
稍微摸了一下
不知如何設置UDP SERVERIP:224.0.0.50
點了UDP Server
按創建
僅有端口能設置
無法設置ip..
若端口設置4321時
ip卻是127.0.0.1
懇請教學
感謝您
czde
发表于 2018-10-11 22:00:09 | 显示全部楼层
MagicGhost 发表于 2018-10-10 22:24
抱歉
小白找到了此軟體
你把启动后的日志发上来吧。。。
GMT+8, 2025-12-16 20:00 , Processed in 1.298744 second(s), 12 queries , MemCached On.
