查看: 7372|回复: 3
[求助] 小米万能遥控器无法学习?
发表于 2018-10-3 05:01:19 | 显示全部楼层 |阅读模式
配置文件
remote:
  - platform: xiaomi_miio
    host: 192.168.31.19
    token: 614e9c675c49dbe464cb84ea523fc959
    slot: 14
    timeout: 30
    hidden: false
    commands:
      1:
        command:
          - raw:123456
页面上也没有控件
万能遥控器
万能遥控器
错误日志
2018-10-03 04:52:44 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=remote, service=xiaomi_miio_learn_command, service_data=entity_id=remote.ir_remote, service_call_id=7b4bdc09519644298be69513134cf117>2018-10-03 04:52:44 ERROR (MainThread) [homeassistant.components.remote.xiaomi_miio] entity_id: 'remote.ir_remote' not found2018-10-03 04:52:44 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=7b4bdc09519644298be69513134cf117>
万能遥控器学习的前提条件是什么?还需要安装什么插件?python-miio我安装了
 楼主| 发表于 2018-10-3 14:00:45 | 显示全部楼层
没人吗?
 楼主| 发表于 2018-10-4 22:42:51 来自手机 | 显示全部楼层
有人帮忙解决下吗,
 楼主| 发表于 2018-10-5 14:25:32 | 显示全部楼层
我换成syssi版本的chuangmi_ir可以使用,但是脚本发送码又出错了
Error executing service <ServiceCall switch.send_command_192_168_31_19 (c:c01a18be5e8a4e828198de5fbaa0a084): command=['Z6VHADgCAACVBgAAvwgAAG8RAABDIwAAYiMAALyYAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA1ABAAABAQAAAQABAQAAAQEBAAAAAQEBAAABAQEAAAABBgJAA=']> Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/homeassistant/core.py", line 1177, in _event_to_service_call await service_handler.func(service_call) File "/usr/local/lib/python3.6/asyncio/coroutines.py", line 212, in coro res = func(*args, **kw) File "/config/custom_components/switch/chuangmi_ir.py", line 115, in _send_command ir_remote.play_raw(command, 38400) File "/config/deps/lib/python3.6/site-packages/miio/chuangmi_ir.py", line 64, in play_raw {'freq': frequency, 'code': command}) File "/config/deps/lib/python3.6/site-packages/miio/device.py", line 270, in send raise DeviceError(m.data.value["error"]) miio.exceptions.DeviceError: {'code': -5008, 'message': 'magic error'}
提交给github了,https://github.com/syssi/chuangmi_ir/issues/13
GMT+8, 2025-11-7 00:30 , Processed in 1.075354 second(s), 11 queries , MemCached On.
