查看: 6244|回复: 1
[求助] 各位帮帮忙 看看什么情况 无法启动
发表于 2018-9-30 16:07:20 | 显示全部楼层 |阅读模式
  用pip3 成功安装homeassistant后无法启动,什么意思阿   谢谢各位  系统是ubuntu18.4
    Successfully uninstalled aiohttp-3.4.4
Successfully installed aiohttp-3.1.3 async-timeout-2.0.1 attrs-18.1.0 homeassistant-0.70.0 requests-2.18.4 typing-3.6.6 voluptuous-0.11.1
rex@H:~$ hass
  File "/usr/lib/python3/dist-packages/secretstorage/util.py", line 31, in function_out
    return function_in(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/dbus/proxies.py", line 145, in __call__
    **keywords)
  File "/usr/lib/python3/dist-packages/dbus/connection.py", line 651, in call_blocking
    message, timeout)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.UnknownMethod: 在路径 org.freedesktop.DBus.Properties 的对象上没有 /org/freedesktop/secrets/collection/login 接口
  File "/usr/local/bin/hass", line 11, in <module>
 楼主| 发表于 2018-9-30 20:50:26 | 显示全部楼层
有一个学计算机的朋友说 是homeassistant 没有安装完全  试试看
GMT+8, 2025-11-7 00:31 , Processed in 0.997410 second(s), 7 queries , MemCached On.
