楼主: yinjiong
[插件集成] 斐讯M1离线版,支持屏幕亮度设置
发表于 2024-10-12 16:25:18 | 显示全部楼层
支持一下,不错。
发表于 2024-10-14 09:37:08 | 显示全部楼层
支持一下
发表于 2024-11-11 22:40:08 | 显示全部楼层
看起来不错
发表于 2024-11-24 11:14:56 | 显示全部楼层
经典的帖子
发表于 2025-1-10 09:05:49 | 显示全部楼层
好像现在我们正在高科技!!
发表于 2025-1-15 21:49:23 | 显示全部楼层
看看先,不知有用否
发表于 2025-1-26 16:20:15 | 显示全部楼层
这个很好,感谢分享
发表于 2025-1-31 23:04:11 | 显示全部楼层
感谢大佬
发表于 2025-2-9 22:23:04 | 显示全部楼层
升级到最新2025.2.1版本,这个组件好像已经失效了
报错如下:
Detected blocking call to import_module with args ('custom_components.aircat.sensor',) in /usr/src/homeassistant/homeassistant/loader.py, line 1304: return importlib.import_module(f"{self.pkg_path}.{platform_name}") inside the event loop; This is causing stability issues. Please create a bug report at https://github.com/home-assistan ... s%3Aopen+is%3Aissue For developers, please see https://developers.home-assistan ... ions/#import_module Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 227, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 213, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 154, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.13/asyncio/base_events.py", line 707, in run_until_complete self.run_forever() File "/usr/local/lib/python3.13/asyncio/base_events.py", line 678, in run_forever self._run_once() File "/usr/local/lib/python3.13/asyncio/base_events.py", line 2033, in _run_once handle._run() File "/usr/local/lib/python3.13/asyncio/events.py", line 89, in _run self._context.run(self._callback, *self._args) File "/usr/src/homeassistant/homeassistant/config.py", line 1055, in _async_load_and_validate_platform_integration platform = await p_integration.integration.async_get_platform(domain) File "/usr/src/homeassistant/homeassistant/loader.py", line 1108, in async_get_platform platforms = await self.async_get_platforms((platform_name,)) File "/usr/src/homeassistant/homeassistant/loader.py", line 1173, in async_get_platforms platforms.update(self._load_platforms(platform_names)) File "/usr/src/homeassistant/homeassistant/loader.py", line 1098, in _load_platforms platform_name: self._load_platform(platform_name) File "/usr/src/homeassistant/homeassistant/loader.py", line 1272, in _load_platform cache[full_name] = self._import_platform(platform_name) File "/usr/src/homeassistant/homeassistant/loader.py", line 1304, in _import_platform return importlib.import_module(f"{self.pkg_path}.{platform_name}")
使用chatgpt分析,修改建议如下:
https://chatgpt.com/share/67a8ba12-b628-8007-9794-9769b9c67b3b
但我不会修改,看着原来是thread方式启动,可能得改这里?
发表于 2025-2-13 23:06:05 | 显示全部楼层
KANKAN ZENMEYANG
GMT+8, 2026-2-4 22:12 , Processed in 0.057916 second(s), 10 queries , MemCached On.
