楼主: yinjiong
[插件集成] 斐讯M1离线版,支持屏幕亮度设置
发表于 2021-10-5 21:36:48 | 显示全部楼层
支持大佬!
发表于 2021-10-12 22:20:49 | 显示全部楼层
6666666666666666666666666
发表于 2021-10-13 18:06:02 | 显示全部楼层
楼主,你是一个大好人!!
发表于 2021-10-17 23:14:44 | 显示全部楼层
看看这个,刚搞了一个试试看
发表于 2021-10-19 21:31:14 | 显示全部楼层
houyawei 发表于 2021-8-4 21:09
不刷估计这个最好用。
--------------------------21.08.11编辑
你好,我按照up的这个配置了,配置检查那里就报错了,无法重启
nvalid config for [input_select]: expected a dictionary for dictionary value @ data['input_select']['brightness_m1a']. Got None
expected a dictionary for dictionary value @ data['input_select']['name']. Got '亮度'
expected a dictionary for dictionary value @ data['input_select']['options']. Got ['关闭', '夜间', '白天']
extra keys not allowed @ data['input_select']['group']['m1a']. Got OrderedDict([('name', '客厅M1'), ('view', False), ('entities', ['sensor.m1_hcho', 'sensor.m1_humidity', 'sensor.m1_pm25 - sensor.m1_temperature - input_select.brightness_m1a'])])
extra keys not allowed @ data['input_select']['group']['m1b']. Got OrderedDict([('name', '卧室M1'), ('view', False), ('entities', ['sensor.m12_hcho', 'sensor.m12_humidity', 'sensor.m12_pm25', 'sensor.m12_temperature', 'input_select.brightness_m1b'])])
required key not provided @ data['input_select']['group']['options']. Got None. (See /config/configuration.yaml, line 47).
Platform error sensor.aircat - Integration 'aircat' not found.
发表于 2021-10-19 23:28:16 | 显示全部楼层
这玩意现在还能用不 专门注册了就是想把M1给复活
发表于 2021-10-23 22:58:29 | 显示全部楼层
发表于 2021-10-28 14:22:15 | 显示全部楼层
学习下怎么配置..
发表于 2021-11-1 11:54:36 | 显示全部楼层
支持屏幕亮度设置
发表于 2021-11-2 13:52:46 | 显示全部楼层
谢谢分享!看看
GMT+8, 2026-2-5 06:23 , Processed in 0.071297 second(s), 10 queries , MemCached On.
