发表于 2020-3-13 15:47:46
显示全部楼层
Exception: Traceback (most recent call last): File "/config/custom_components/phicomm_m1_sensor/sensor.py", line 51, in update self.handle(fd) File "/config/custom_components/phicomm_m1_sensor/sensor.py", line 58, in handle data = conn.recv(4096) # If connection is closed, recv() will result a timeout exception and receive '' next time, so we can purge connection list ConnectionResetError: [Errno 104] Connection reset by peer
Closed <socket.socket fd=19, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0, laddr=('192.168.2.3', 9000)>
Closed <socket.socket fd=31, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0, laddr=('192.168.2.3', 9000)>
Closed <socket.socket fd=33, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0, laddr=('192.168.2.3', 9000)> |
